Rattle : Supercharger / water pump
Old Aug 23, 2010 | 05:23 PM
  #476
mylittleshoe's Avatar
mylittleshoe
The front had oil in it, but ill ask him when i see him tomorrow thanks for input.
Old Aug 24, 2010 | 01:03 AM
  #477
Cadenza's Avatar
Cadenza
Originally Posted by jhiggs26
While he's there he may want to pull the snout and inspect the coupler for oval holes.
Jeremy
When the coupler becomes loose (from the holes turning oval). does it make any noticeable noise... ie rattle?
Old Aug 24, 2010 | 08:56 AM
  #478
jhiggs26's Avatar
jhiggs26
I've never experienced noise from egged coupler holes first hand. The 2 couplers I've pulled only had ever so slight egging and no apparent noise(on my stock blower).
Just google and/or youtube eaton noises and make your own determination. To me when the bypass valve closes I don't want any slop. Slop will cause wear and shock to the whole system.
If it were me I'd pull the snout inspect it. ie bearings, seal, coupler, oil and rotor gears. Couplers, seals, bearings and oil are cheap.
Jeremy
Old Aug 24, 2010 | 09:05 AM
  #479
brouwerj's Avatar
brouwerj
bleeders
Does anyone know the number and location of all the bleeder valves in the coolant system? Also does anyone know the pressure (psi) within the coolant system? Gracias.
Old Sep 12, 2010 | 06:58 AM
  #480
welcha13's Avatar
welcha13
After reading this thread I've become concerned about a rattle from my R53. This rattle seems to be coming from the engine/passenger side and is loudest when coming off of idle (most often when the clutch is being engaged at low RPMs). I can usually minimize the noise by having a slightly higher rev and playing with the clutch a bit off the start. I've thought this to be the tensioner pulley and belt. There is usually a squeak from the belt if I shift hard in the upper RPMs. The noise can be heard at idle when the engine is cool and only slightly when warmed up. It is not apparent at cruising speeds.
Does the supercharger rattle constantly? Only at idle? I've got 70k miles on my '06.
Old Sep 12, 2010 | 03:56 PM
  #481
Hankfrum's Avatar
Hankfrum
My SC is going south. The sound you are looking for is really loud. Its hard to pinpoint it from just looking at it. Take a long screwdriver and put it on the charger on the driver side, believe you'll know if its that. Also you'll notice a faint "clinking sound" that will usually mature to a full blown sound of coins in a coffee can. Mine has not got that bad yet but i imagine its not far off. That being said im thinking of rebuilding the back end of my SC. Ive found the gears online and being a machinist feel the rebuild is not to difficult. Harder to get to then anything. Has anyone rebuilt the rear end and if so what all should i get. Another question, will i have to worry about the debris from the gear failure being ingested thru the seals or anywhere on the back for that matter?
Old Sep 13, 2010 | 09:48 AM
  #482
jhiggs26's Avatar
jhiggs26
The oil seal should keep debris from getting into main case/rotors. Modify a tie rod end puller to fit underneath the pto gear to pull if off the shaft. Bake new gear and quickly seat it onto shaft(tap it home to same level as before and keep other end static to prevent endfloat changes). The waterpump drive should be easy to re and re the gear, bearing and seals. Good luck!
I spoke to a supplier about seals and bearings for our M45's and they've got front seals and PTO refresh kits for sale now. The rear needle bearings are still on 40 week back order.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWAX:IT
Jeremy
Old Sep 20, 2010 | 05:43 PM
  #483
welcha13's Avatar
welcha13
I talked to a guy from Endyn and he said check out Magnuson Products for gear and rotor replacements in the MINIs M45.
http://www.magnusonproducts.com/
Old Sep 21, 2010 | 01:34 PM
  #484
jimz68's Avatar
jimz68
I just spoke with them and was told they are not re-building MINI superchargers because they "can't get the little gears".
Spoke with PS Superchargers also. They said you have to buy a new unit if your PTO gears are shot.
Jim
Old Sep 22, 2010 | 12:04 AM
  #485
Cadenza's Avatar
Cadenza
Jim
PS Superchargers... do mean PSE Superchargers?
Looks like the number of re-builders are dwindling. Steigemeier is still doing it.... http://www.stiegemeier.com/pricing.html
Old Sep 22, 2010 | 07:19 AM
  #486
jimz68's Avatar
jimz68
You are correct, sir! I did mean PSE.
Also, the High Speed Lab, through autoXcooper.com does the rear gears.
Now...which one to use? Hmmmm..............
Thanks!
Jim
Old Sep 22, 2010 | 07:48 AM
  #487
ZippyNH's Avatar
ZippyNH
One thing to say...some rebuilders do not replace the seal that keep the lube in the rear gears...them saying they do not/can not/don't do it anymore might indicate that after they did rebuilds in the past with new gears, they still ran dry, and were destroyed...cause the seal did not get 100% replaced, or was previously compromised.
Gears are sold (last time I checked) by a few companys that rebild the sc to other dealers...so them saying they can't get them might be more of an admission that if there is a defect in this area, they do not/cannot fix it with certainty.
Just a thought.
Old Oct 30, 2010 | 03:35 PM
  #488
brouwerj's Avatar
brouwerj
got pump installed but.
I successfully replaced the mechanical pump on my r53 with an electric water pump. However, for some reason when i drive it now it overheats after a few miles. Im not sure but I think it might have to do with the fact that the pump is always on full blast and is creating some kind of air pocket in the system. It ran fine at idle for a long time, but when i tried to drive it and got some heat to the engine, the overflow tank overflowed and spewed fluid all over the engine compartment. Does anyone know if I should take out the thermostat and put in an electric thermostatic switch to control the pump? That's my only idea. If anyone has another idea let me know.
Old Oct 30, 2010 | 03:56 PM
  #489
ZippyNH's Avatar
ZippyNH
Try re-bleeding it...sounds like similar symtoms to a faulty bleed (air pockets) after work on the cooling system...
Old Oct 30, 2010 | 07:59 PM
  #490
jimz68's Avatar
jimz68
Well, I sent off my spare supercharger to Steigemeier last Thursday. Having the "Front-Drive Rebuild Plus Water Pump Drive Rebuild" done. Spoke with Robyn there. Very nice and helpful.
I'll snap a few photos upon it's return.
Jim
Old Nov 5, 2010 | 07:08 PM
  #491
brouwerj's Avatar
brouwerj
Wow. fixed.
So after much experimentation and error and discovery, I have finally bypassed the broken, noisy, unreliable gear-driven water pump for a relatively inexpensive yet very durable electric pump setup. It took me a long time but I had no previous mechanical experience, and therefore this procedure could be done by anyone. I have over a hundred pictures of the process and when I get a spare few days (I work as a very busy EMT in Indianapolis so that might be difficult to come by) I will try to write up a full how-to on the process including pictures, part numbers, cost estimates, etc. Just so everyone knows, if your supercharger gears are going bad, don't spend thousands! It can be fixed for hundreds! PM me with specific questions, but keep in mind I won't be able to get the written how-to up for a little while yet.
Old Nov 6, 2010 | 10:59 AM
  #492
Cadenza's Avatar
Cadenza
Looking forward to your write-up.
Old Nov 7, 2010 | 12:28 PM
  #493
AKIndiMini's Avatar
AKIndiMini
+1
Old Nov 7, 2010 | 05:25 PM
  #494
Ric in Richmond's Avatar
Ric in Richmond
Can't wait to see the write up. The electric conversion should be interesting especially the way the water pump integrates into the SC/ block.
Old Nov 7, 2010 | 06:56 PM
  #495
ZippyNH's Avatar
ZippyNH
It is also a way to get an extra hp or two out of the car on a hard pull, hottrodders have been doing it for years...not a big differance, but a tiny bit more compared to a similar car...
Might be interesting to see how it works long-term.
Old Dec 29, 2010 | 02:09 PM
  #496
mini53's Avatar
mini53
So I read through this whole thread, guess I should be considered the lucky one with 133,000 miles on a 2002 original SC.
Last talk early this year seems to indicate that only a few places are left for a good rebuild, what are they now almost 1 year later?
http://www.stiegemeier.com/home.html seems to be one.
Any others?
I am thinking at this point I should just spend the money and be done with it as it is a matter of time.
Thoughts?
Old Dec 29, 2010 | 02:12 PM
  #497
wrh3's Avatar
wrh3
I would go to www.waymotorworks.com to have mine rebuilt when the time comes......
Old Dec 29, 2010 | 06:25 PM
  #498
Ric in Richmond
SNIP
Thoughts?
I'd definitely do an oil service front and rear. Mine were fine at 160000+ but were nearly empty.
Old Dec 30, 2010 | 05:52 AM
  #499
CarGuyNeil's Avatar
CarGuyNeil
Thoughts?
I agree, it is just a matter of time. I would recommend doing it before you have the teeth on the gears chew themselves up. Preventative maintenance...
Old Dec 30, 2010 | 06:57 AM
  #500
mini53's Avatar
mini53
Did you determine where the oil went? Out a seal or into the intake chamber?
