Speedo Question
Old Oct 26, 2005 | 08:22 AM
FlynHawaiian's Avatar
FlynHawaiian
Speedo Question
Curiosity is killing the cat here. I was curious if there is a way to display how fast you are going, digitally on the tach, or is it possible to put a small little readout to tell you your speed so you don't have to look over?
Old Oct 26, 2005 | 08:29 AM
The Short Bus's Avatar
The Short Bus
i have a little button on my turn signal to flip from temp outside to my digital speed.
but as i found out this weekend, not everyone has it
Old Oct 26, 2005 | 10:11 AM
Red Ryder's Avatar
Red Ryder
Coordinator :: Tar Heel MINI Motoring Club
Since you have the '06 with the Premium Package. You should be able to toggle through the various options, one of which is digital speed. Look on your turn signal stalk for the button on top.
Old Oct 26, 2005 | 10:14 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
Its one of the displays for the OBC.
Old Oct 26, 2005 | 10:49 AM
Eric_Rowland's Avatar
Eric_Rowland
Above statements are true as long as you don't have Nav or Chrono. If you have the speedo in on the column (apparently not in your case), there's no digital option.
Old Oct 26, 2005 | 06:04 PM
Zman's Avatar
Zman
sure would like a decent clock display...
the size of the numbers in the display are "mini"...
a nice analog clock on the dash would be great...
Old Oct 27, 2005 | 12:54 AM
Eric_Rowland
Then you need to 'downgrade' to an '04. We have a nice big one up in the headliner. We don't get the nice lower gearing though...
Helped a fellow NAMer change his clock - it was a RPA! (Raging Pain in the ...)
Personally, as A/R as I am, I'd like to have digital speed readout as well - analog is great for visual rate of change, but digital is nice for steady state. I do have the OBC 'avg speed' with the nav, but it's not nearly as fun reseting it constantly.
Old Oct 27, 2005 | 11:06 AM
FlynHawaiian
It would be kinda cool if there was a display or a heads up option on the windshield like some of the bmws. I'm not sure this is even possible, but a small display on the windshield that had rpms, speed and what gear your in would be pretty trick. I'm guessing even in a manual the computer knows your in 1st or 5th gear. Would be pretty neat.
http://www.nippon-seiki.co.jp/defi/p...ncept_top.html
donniedarko
Oct 21, 2015 01:15 PM
JaggerCoop
Sep 15, 2015 06:17 AM
Panik
Sep 9, 2015 08:36 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
