O5 mcs odd exterior light issue…
Old Aug 25, 2023 | 12:55 PM
kjkociba's Avatar
kjkociba
Scratching my head on this, my flashers came on on their own, along with srs and airbag lights illuminating in dash. After turning car off and back on, srs light is off, hazard indicator is no longer active but now only some (abaiut half) exterior lights work. Driver low beam, passenger high (and driver low stays on when switching to high) right rear running light works, passenger side is out, no blinkers (although dash indicator lights up and clicks.. hazard indicator clicks with no external lights flashing.
After reading some other threads all fuses look and test good, I’ve put in a known good battery in, same issue, I don’t see any water ingress in BCM or battery box, but have swapped BCM with a spare, no change. All other functions work, and car runs and drives without issue. Anyone run across this before? Scan tool shows a slew of module communication failures, but so far I have yet to locate a break anywhere on the kbus. Thoughts?
Old Aug 26, 2023 | 09:59 AM
kjkociba's Avatar
kjkociba
And fixed… driver side rear brake light harness had been partially pinched by the housing somwtime in the past and it rubbed through insulation, and fl12 fuse was in a partially corroded socket. Love how everything is tied together now on cars!
Old Aug 26, 2023 | 02:13 PM
Here2Go's Avatar
Here2Go
NAM Community Team
105 views and "crickets"
Glad you were able to figure it out yourself
' gotta love a happy ending
Damama1996
Nov 13, 2017 06:13 AM
KSutherland
R55 :: Clubman Talk (2008+)
Sep 6, 2016 07:34 PM
Buzzbcooper
Oct 29, 2014 08:45 AM
Red
Jul 10, 2012 02:00 PM
Happy Sheep
Jan 6, 2011 07:06 PM
