R50/53 Electrical Apocalypse
Old Jul 10, 2012 | 10:59 AM
Red's Avatar
Red
Posted that my airbag light and seat belt light stayed on a couple of weeks ago on my low mileage 06 MCS.
Now it keeps piling on:
- Airbag light
- Passenger Airbag light (intermittent)
-Seat Belt light
- Doors won't lock, brake lights stay lit a few minutes, then you are able to lock
- ABS light goes on
- Clock goes off
- No signal lights
- A/C does not go on right away.
Where is Joe Lucas when you need him?
Sounds like in addition to a body module; I need every module made.
Or a match?
Old Jul 10, 2012 | 11:17 AM
69shelby's Avatar
69shelby
check your battery voltage
Old Jul 10, 2012 | 11:51 AM
Red's Avatar
Red
Good call! I was wondering how all the modules would go down at once. Power source!
Going to get on that right away and keep you posted.
Why do I always look at the expensive stuff first?
Old Jul 10, 2012 | 11:57 AM
bmwr606's Avatar
bmwr606
i think you have a grounding issue
have the battery "load tested" because that is easy to have done (sears, batteries plus, autozone, etc), but if the car starts readily, i doubt it is the battery, more likely chassis ground issue....
flakey ground = flakey computer
scott
Old Jul 10, 2012 | 12:22 PM
Red's Avatar
Red
scott
Voltage may be good to spin a starter motor, but the electronics could be finicky.
Will check grounds too. Thanks!
Old Jul 10, 2012 | 02:00 PM
Red's Avatar
Red
Battery good. Alternator NFG. Sending out bad voltage.
Going to be FUN to replace.
USNAE2
16
Jun 17, 2022 07:17 AM
ryGuyMCS
Oct 6, 2015 12:04 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
FatherG
Sep 27, 2015 05:12 AM
asmasm
Sep 21, 2015 08:23 AM
