R56 K-Can line fault issues
Old May 28, 2023 | 02:08 PM
chucky5150's Avatar
chucky5150
Hey y'alls,
2009 S
sunroof
6-speed
117,000ish miles
Spent the day working on clearing the 93C3 - Seat occupancy detector error. Got that cleared out now. On to the next set.
Error codes:
  • E584 K-CAN line fault
  • DA04 K-CAN line fault
  • E104 K-CAN line fault
  • C944 K-CAN line fault
  • D904 K-CAN line fault
I can't really find much information of these.
Any ideas how I'd go about troubleshooting these?
Thank you
Old Jun 3, 2023 | 07:19 PM
Yoshimura 1's Avatar
Yoshimura 1
Waiting to see some info on this........
Old Jun 9, 2023 | 10:22 AM
allenm324's Avatar
allenm324
https://bmwfault.codes/
Gives a little more info on the codes but no details.
Old Jun 9, 2023 | 12:41 PM
mrbean's Avatar
mrbean
CAN line faults are caused by either faulty wiring, faulty terminating resistors, or a faulty module.
The first two are easy to check with a multimeter and a wiring diagram. You'll want to check both the CAN_L and CAN_H wires - they are green and green with red stripe, respectively. They will be twisted together:
There should be no conductivity to ground. There should be no battery voltage from wire to ground or wire to wire. There should be 120 ohms from wire to wire.
You only need to check these in one spot in the harness, not at every module.
Faulty module detection can be tricky. This is where an oscilloscope makes the job infinitely easier. Basically, you're looking for a clean square wave signal on the wires. White noise or other interference suggests a bad module. You can find the culprit by disconnecting each module one-by-one from the harness until the signal is clean. I'd start with the FRM as these have a certain reputation.
Good Luck!
Edit: You'll also want to check continuity of the the wires between each module. But this is time consuming and it's worth doing the o-scope check first.
Old Jun 10, 2023 | 02:11 PM
chucky5150's Avatar
chucky5150
just what I needed
Good Luck!
Awesome info. Thank you for that. Now I just need to find this when I get back to my breast in a few weeks.
Old Jun 13, 2023 | 07:18 PM
Yoshimura 1
That site gives you a pretty good idea where to start looking at locations for finding the K can issues.......
Old Jul 2, 2023 | 09:54 AM
chucky5150's Avatar
chucky5150
Any tips on the best way to get to these wires without damaging them?
Old Dec 4, 2023 | 10:52 AM
Yoshimura 1
I'm getting ready to tackle this issue.......
Old May 27, 2024 | 04:06 AM
Michel9352's Avatar
Michel9352
Hello,
Did you ever found the issue?
I have the same issues.
Thanks in advance
Old Jun 4, 2024 | 04:07 PM
RUPNOK's Avatar
RUPNOK
Post is 6 months old. Look at your junction box for corrosion from the sunroof.
Old Jun 26, 2024 | 06:34 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Originally Posted by chucky5150
2009 S
sunroof
6-speed
117,000ish miles
Error codes:
Did you try unplugging the seat occupancy detector to see whether these K-CAN codes cleared?
Mereco
Sep 6, 2022 05:51 PM
steve05ram360
Aug 27, 2020 02:43 PM
CSP
Jun 9, 2019 05:26 PM
M3This
Tires, Wheels, & Brakes
Aug 16, 2009 11:32 AM
