Bad Map Sensor?
Old May 16, 2023 | 10:06 AM
Rehm11's Avatar
Rehm11
Bad Map Sensor?
i have a 04 MCS with dominator cam, 15% reduction pulley, 550 injectors tuned by rmw. i have a longer than usual cranking to fire it up also runs a bit rough at idle and misfires slightly. Drives fine until coming to a stop then its rough and misfires. While looking on the obd scanner i noticed with the ignition on engine off the tmap was at a certain number ( lets say 1735 i cantv remember exactly) and the map sensor value on scanner was jumping from 1700-1800. am i right to say i have a bad map sensor ?
Old May 17, 2023 | 03:35 PM
Daftlad's Avatar
Daftlad
Sounds like it, or its TMAP twin. In case it helps, from Bentley's MINI Cooper / Cooper S 2002-06 Diagnosis without Guesswork:
TMAP and MAP Sensors (Cooper S) p. 13-118
TMAP and MAP Sensors (Cooper S) p. 13-119
TMAP and MAP Sensors (Cooper S) p. 13-120
TMAP and MAP Sensors (Cooper S) p. 13-121
Old May 17, 2023 | 04:20 PM
Ngtphantom's Avatar
Ngtphantom
Do you have an afr guage and have you checked if your car is running perhaps on the rich side due to the tune and the 550 injectors ? Afr guage may help to point you as to what is happening during the bogging .
SupeR53
Apr 14, 2022 07:04 AM
OCKOLBY
Nov 5, 2015 07:28 AM
maddog
Oct 9, 2010 07:08 AM
SpiderX
Jun 30, 2005 05:48 PM
