R50/53 Oxygen sensor voltage flutuation
Old Apr 13, 2022 | 07:32 AM
SupeR53's Avatar
SupeR53
I found the other day that my OBD diagnostic unit will also send the Oxygen sensor voltage values to my phone. Being curious, I watched them as I drove home (32miles flats and canyon) and noticed that the upstream sensor (sensor 1) would fluctuate between around 0.1 and 0.7V at idle, while the downstream sensor sat quite stable around 0.1V. While driving, the two would, at times, mirror each other, at others the upstream would bounce by up to 1V. Not knowing how the ECM evaluates this, I thought that I'd ask the combined wisdom-Is this normal or should I change out the upstream ox sensor?
Details on Tigger, 188k miles, original engine, super, 15% pulley, 2% overdrive crank pulley, JCW CAI.
Thanks in advance,
Old Apr 13, 2022 | 09:49 AM
AcidK1's Avatar
AcidK1
I think there the same sensor so possible swap them over and see if anything changes? Not 100% on that
Old Apr 13, 2022 | 10:16 AM
dmath's Avatar
dmath
I'm not sure about the post-cat sensor but I think the pre-cat sensor should fluctuate in roughly the range you mention.
Old Apr 13, 2022 | 05:16 PM
deepgrey's Avatar
deepgrey
IIRC, full range for the O2 sensor is 1 V. It’s normal for the upstream sensor to fluctuate during closed loop as the DME adjusts the mixture. The post-cat sensor won’t read the same because the cat absorbs/uses oxygen if it’s functioning properly.
Old Apr 13, 2022 | 07:19 PM
A383Wing's Avatar
A383Wing
your readings are normal....just enjoy the car
(our cars run a little rich most of the time anyway)
Old Apr 14, 2022 | 07:04 AM
SupeR53's Avatar
SupeR53
Cool, Thanks for the info, now to return to driving it like I stole it!
MiniManAdam
Nov 3, 2020 10:06 AM
northbarts
Feb 24, 2013 12:31 PM
auscoops
Dec 4, 2008 04:12 AM
pmello
Jan 24, 2006 06:55 PM
SpiderX
Jun 30, 2005 05:48 PM
