Air bag light question
Old Feb 4, 2022 | 12:02 PM
A383Wing's Avatar
A383Wing
I hope I put this question in the correct place.
Car is 2006 R52 JCW. The passenger front seat mat was replaced by dealer a couple years ago.
Here's the issue I am having with the yellow light in the header panel:
Light is off when nobody is sitting in passenger seat
Light is on when my dog or someone is sitting in the passenger seat
Light stays on when passenger seat belt is buckled
Light is on when belt is buckled and nobody is sitting in the passenger front seat
There are no codes for the SRS system
The little red light goes out in the dash when I buckle the driver's side seat belt.
My question is this: Could it be possible that the previous owners deactivated the passenger side air bag at some point? Or do I need to look at something else?
Bryan
Old Feb 4, 2022 | 12:53 PM
deepgrey's Avatar
deepgrey
It sounds normal except for "Light is on when someone is sitting in the passenger seat." I assume said someone is a full-grown adult?
Old Feb 4, 2022 | 01:36 PM
A383Wing's Avatar
A383Wing
Did you read the full post? I stated when the light is on and off....I can even make the light come on when I push my hand on the passenger seat.
So, normal for you is the light is on when someone is sitting in the passenger seat, and seat belt is buckled? Light should be off if my thinking is correct.
I don't think this is the way it's supposed to work
Bryan
Old Feb 4, 2022 | 01:56 PM
deepgrey's Avatar
deepgrey
Yeah, I read the whole post, bud. You didn't answer my question. It's weight based. Is the "someone" an adult? If the "someone" is an adult, then it's not working right, and I would guess a faulty mat. A dog is possibly not heavy enough to turn that airbag on. Same goes for your hand. I'm pretty sure I remember buckling the belt with no one in the seat would also turn the light on, but I haven't tried it in years. Someone with a working mat should be able to confirm that.
Normal for me is the light is always off because I shut the sensor off in software.
Old Feb 4, 2022 | 02:02 PM
A383Wing's Avatar
A383Wing
Light is on when I am sitting in the passenger seat with seat belt buckled. Light is on when my dog of 40lbs is sitting in the passenger seat with belt buckled or unbuckled with me driving.
Old Feb 4, 2022 | 02:10 PM
deepgrey's Avatar
deepgrey
Yep, that ain't right.
Now that I think about it, I'm pretty sure I had a code when my mat was failing though. It was intermittent, and it would light the SRS light in the speedo. Hmm...
I don't know how it acts if the airbag is deactivated.
Old Feb 4, 2022 | 02:15 PM
A383Wing's Avatar
A383Wing
I just got off the phone with the dealer, they replaced the seat mat under recall in 2019..... They say that I need to bring it back in for diagnosis, at the cost of $200
Old Feb 4, 2022 | 02:18 PM
deepgrey's Avatar
deepgrey
Ugh. If you have INPA and NCSExpert, you could pull the settings from the airbag module and take a gander at them.
It looks like it would probably be the AIRBAG_BEIFAHRER_1 option to turn the passenger airbag on or off, so you could check that to see if it's been disabled. Perhaps someone else can confirm that setting.
@adriancl , do you have any thoughts? I don't know if the euro cars got the same mats that we did in the states.
Old Feb 4, 2022 | 03:51 PM
A383Wing's Avatar
A383Wing
I have the computer program to get into the BCM for re-coding.....it's on my laptop, just have not pulled the trigger and connected it to my car yet
Old Feb 6, 2022 | 08:15 PM
ssoliman's Avatar
ssoliman
Do you have a code when u scan w inpa?
Old Feb 6, 2022 | 08:23 PM
A383Wing's Avatar
A383Wing
I don't have INPA.... I have a Foxwell scanner that reads SRS system codes, and no, I have no codes
Bryan
Old Feb 6, 2022 | 08:29 PM
ssoliman's Avatar
ssoliman
Guess I’d clean the connector under the seat.
then I’d call another dealer and double check the mat recall. We had ours replaced also. Prob the mat is bad.
Old Feb 6, 2022 | 08:43 PM
A383Wing's Avatar
A383Wing
The connector under the seat is good, I double checked it today....
Scroll up and see reply #7 about the dealer
Bryan
David.R53
Apr 17, 2015 11:00 AM
HarlequinAuthor
Jan 29, 2015 07:20 PM
jontalk
Oct 15, 2007 04:20 PM
4weiners
Oct 2, 2007 06:58 AM
uncle
Feb 13, 2005 08:21 AM
