Gen1 window adjustment
Old Jan 16, 2022 | 01:35 PM
Eric_Rowland's Avatar
Eric_Rowland
Had my driver's window broken and replaced last year, but in addition to not removing all the broken glass, the shop didn't adjust the window properly, so I've had wind noise ever since. At first I thought I needed a new gasket (after almost 20 years), but it turns out they just didn't adjust the window correctly.
Forgot to take a pic, but it was obvious after inspection that the rear of the glass wasn't parallel to the B pillar.
Here's where I found the solution:
https://tasteslikepetrol.net/2020/08...ow-adjustment/
If NAM doesn't like the link, there are two 'gears' on the front and back of the window.
Repair sequence:
1 - lower window, lift out window trim from top of door, it just lifts out.
2 - raise window. You'll see two plastic wheels front and back on the outside of the window.
3 - The OEM tool grabs these wheels to loosen the window, but they can also be loosened with a flat blade and a hammer. (lefty, loosey!)
4 - after loosening the 'gears', adjust the window (I used my passenger side as a guide) and snug up the 'gears' again.
5 - lower window, replace trim
Motor on!
Old Jan 16, 2022 | 01:50 PM
Eric_Rowland
Images, FWIW
front window 'gear'
rear window 'gear'
window diagram (thanks, PP!)
Old Jan 17, 2022 | 01:14 PM
Thats great, this is the info i posted a while back that might help also.
https://www.northamericanmotoring.co...regulator.html
https://www.northamericanmotoring.co...djustment.html
ghostwrench
Aug 1, 2020 09:19 PM
traildog
Apr 6, 2015 10:41 AM
Jones424
Jan 22, 2015 06:00 AM
OutMotoring
Feb 22, 2005 08:37 PM
LizzyBobio
12
May 18, 2003 07:43 AM
