Rough idle cold start / LPFP & HPFP Diag
Old Nov 25, 2020 | 06:26 PM
joedotmac's Avatar
joedotmac
Having intermittent rough start, car misses for thee to four seconds then the symptom clears.
Is there a known procedure on how to validate the LPFP and HPFP operation at key on and start?
Old Nov 26, 2020 | 04:04 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
DashCommand or Torque apps with an OBD dongle can be used to monitor fuel rail pressure. Key on, engine off, you should see ~70 psi for fuel pressure. That tells you if the low pressure pump is working OK. Engine running at idle, should give you ~700-ish psi to verify the high pressure pump. Engine running under operation, you should see ~1700-ish psi. (If I remember correctly)
Old Nov 26, 2020 | 04:36 PM
joedotmac's Avatar
joedotmac
Thanks for that very helpful. Started this morning without any data logging. Car missed for 30-40 seconds then cleared up and started idling without issue.
Tonight we used both a EL327 dongle and a Foxwell 510 scanner. The EL327 would show us only the high pressure side. At the rail key on got 72.5 psi.
Flipped over to the Foxwell 510 code scanner. It will show and let us log both the low and high pressure. Started car no missing logged 987 to 1066psi at cold idle. The scanner logs the high pressure side in Megapascals
Foxwell--NT.0100003333/scan/BMW/ MINI, Automatic selection, Auto Scan, Live data, {Fuel pressure (high pressure) Rail pressure MPa 7.06 7.00 6.90 6.81 6.86 7.14 7.22 7.10 7.24 6.98 7.10 7.35 7.13 6.99 7.01 6.73 7.11 7.35 7.29 7.30 7.12 7.08 7.17 7.15 7.04 7.11 6.93
Thought I had saved the BMW codes to the Foxwell but now I can't locate them. Did save the OBDII codes from the EL327 and got the following of interest.
P0300
Raw code: 0300
ECU: Engine control unit
Status: Confirmed
OBDII: Random/multiple cylinder(s) - misfire detected
Mini: Random/Multiple Cylinder Misfire Detected
============2==============
P0301
Raw code: 0301
Status: Confirmed
OBDII: Cylinder 1 - misfire detected
Mini: Cylinder 1 Misfire Detected
============3==============
P0303
Raw code: 0303
Status: Confirmed
OBDII: Cylinder 3 - misfire detected
Mini: Cylinder 3 Misfire Detected
Cleared all codes. Planning to hookup the Foxwell in the morning with a cold start log the high pressure side and see if we experience any missing and what the fuel pressure indicates while the symptom is present.
Old Nov 27, 2020 | 06:33 PM
joedotmac's Avatar
joedotmac
Last night after collecting dig information decided to put a few gallons of gas in it. Only 1.7 gallons remaining. Put four gallons in. Went out this morning, started fine without issue. Not willing to blame bad gas on the issue, would be strange. Will try again tomorrow morning to see if the symptom returns.
Old Dec 18, 2020 | 12:07 PM
joedotmac's Avatar
joedotmac
Misfires and cold start idle die condition had returned. Finally found a parameters within the scan tool. FP set point and FP rail pressure. At key on and start the car is commanding "set point" of 9 MPa (Megapascals). When the symptom was present it was clear the HPFP couldn't produce what the DME was commanding and observed at the rail pressure reading. Was able to get a good capture (below). Shared the data with the local Mini service department, with six months of the extended warranty on the HPFP left they replaced the unit.
0.61 is the key on pressure. Upon the first couple frames of the starter engagement, normal operation would expect to see a quick ramp to near 9.XX range. Occasionally during a long idle I recorded pressures falling into the 4's. Tell tale sign of the pump failing. Not conclusive but over the past several years I would get a code set and IC message "operating under reduced power". A key off/on or a clear codes would reset the condition for it to not appear again until months later. Guessing this may have been the early sign of the pump starting to degrade.
Isaiah Yates
Nov 2, 2020 10:43 AM
tachommie
Jun 23, 2017 08:05 AM
InvaderZim
Sep 1, 2011 09:07 AM
sright
22
Sep 2, 2005 07:03 PM
