help
Old Nov 24, 2020 | 09:17 AM
Eric Kotapish's Avatar
Eric Kotapish
help
I have already replaced spark plugs and coils...my mini doesnt cold start that well...and when started goes in and out of limp mode...misfires a lot...starting to wonder if the fuel system is to blame
Old Dec 3, 2020 | 09:38 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Welcome to NAM!
How about some basics - like what year, S or non-S, how many miles, any codes set. People here are happy to help but you have to give us something to go on.
Old Dec 4, 2020 | 05:15 AM
Eric Kotapish
reply
Originally Posted by squawSkiBum
Welcome to NAM!
it's an 07 mini cooper s ....it doesnt make boost all the time either....I'm getting a new turbo for it I figured the wastegate is malfunctioning...I dont think air is the problem I have a k n typhoon installed....and with spark already changed it has to be fuel right???? ...unless the timing in it is taking a crap only when it's cold but that wouldnt make sense...if it was the timing wouldnt it run like crap all the time?
Old Dec 4, 2020 | 05:39 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Could be anything... PCV tube from cam cover to manifold, high pressure fuel pump, turbo, MAF, carbon build up, VANOS solenoids, etc... Need to check for codes with a BMW/Mini specific OBD tool.
Old Dec 4, 2020 | 06:01 AM
Eric Kotapish
only codes ever thrown are multiple misfires detected....and misfire in all the cylinders....and the thermostat is bad ....I erase the codes to.see if anything else comes ...its always the same
Old Dec 4, 2020 | 06:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
What code reader are you using?
Old Dec 4, 2020 | 06:27 AM
Eric Kotapish
autel al619....I know the inside is a little carboned too...I want to take the head off and get it blasted eventually....this is my only car until my nissan is finished....it was fine in the summer...then as soon as it started getting cold it started running like crap
Old Dec 4, 2020 | 06:33 AM
Eric Kotapish
it did throw a knock code before I figured it was predetonation after I changed the knock sensor it was gone....keep in mind I have only had this car about 6 months now....its all new to me...I really like the mini and dont want it to die
Old Dec 4, 2020 | 06:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Unfortunately, I don't think that reader is going to grab the specific codes the Mini ECU will capture for these events. You need a reader built specifically made to interact with the BMW/Mini protocol, like a Foxwell NT530 scanner:
https://www.foxwelltool.com/wholesal...installed.html
However, if you get any general OBD codes from your scanner, drop them into the search box here, and get some good information for diagnostics:
https://bmwfault.codes/
Old Dec 4, 2020 | 06:45 AM
Eric Kotapish
ok I'll pick one up and try it thanks
Old Dec 4, 2020 | 07:03 AM
Jason Cornelius's Avatar
Jason Cornelius
I there a stupid knock code as well, but it turned out to be that i hadnt tightened the hose clamp enough on my OCC, so i had a leak on the driver side PCV. Tightened all my clamps, cleared code, havent seen it since. Might be worth checking those pesky PCV hoses.
Old Dec 4, 2020 | 08:06 PM
squawSkiBum
Moderator
Good advice above. Check out the Gen2 section and the Gen2 FAQs. Then read the Gen2 stock problems and issues section. You're not the first person to have these problems with a 2007-2010 R56S, so research before throwing parts at it. If you have the service records, check them carefully. For a 2007S, first suspects are carbon build up and the HPFP. Check the service records to see if the timing chain tensioner has been replaced.
ccccPUNISHER
Jun 6, 2012 07:50 PM
Bajanmini
Mar 5, 2012 08:45 AM
ACEkraut11
Feb 22, 2008 07:54 PM
Itsdchz
Apr 20, 2005 11:13 PM
