Engine heat causes hood to be very hot.
Old Oct 1, 2020 | 06:29 PM
MiniS08's Avatar
MiniS08
We just had the waterpump, thermostat housing, etc. replaced on our car. It runs fine with the exception of some mild surge while stopped at a traffic light from time to time as well as the hood getting very hot once we park it and the fan doesn't seem to run as long afterwards. We don't get a temp light but the CEL is on. I scanned it but there were no stored fault codes. I checked the fuse and it was good, I read on another thread that lead me to believe it could be a low speed fan resister but I'm not 100% certain of that. Anyone else encounter this situation before?
Old Oct 1, 2020 | 10:16 PM
giorgos's Avatar
giorgos
Originally Posted by MiniS08
We just had the ... thermostat housing, etc. replaced ... We don't get a temp light but the CEL is on. I scanned it but there were no stored fault codes.
What temperatures does the coolant reach during engine operation and after shutdown? If the sensor (inside the thermostat housing) is defective, they may be reported lower than they actually are.
You can easily monitor coolant temperature from inside the "hidden menu":
Old Oct 2, 2020 | 06:01 AM
MiniS08's Avatar
MiniS08
Not sure on the temp, my scanner is supposed to show live data including features like that but it only shows engine rpm. I'll try the hidden menu though. Thanks.
Old Oct 7, 2020 | 07:32 AM
MiniS08's Avatar
MiniS08
Okay got a temp range finally. It keeping stable at 107-108 C, once it shot up to 113 then the fan kicked in high and dropped it back down.
Old Oct 7, 2020 | 08:59 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
107-108C (225F) is normal operating temp for these cars.
Old Oct 7, 2020 | 10:56 AM
MiniS08's Avatar
MiniS08
Okay thanks 🙂👍. I was noticing a pattern once I started monitoring it and was hoping that was the case. I'm used to V8 motors that are set in the 185 or so range.
Old Oct 7, 2020 | 11:25 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
185F is typical for engine cooling temperatures. Hotter operating temperatures increases the engine thermal efficiency. Direct injection engines can run hotter, since they have better control over the combustion process.
Old Oct 7, 2020 | 11:34 AM
giorgos's Avatar
giorgos
Direct injection is not a "pre-requisite": both turbo charged and non-turbo charged engines in the R56 have similar (if not identical) operating temperature ranges, even though the non-turbo charged engines (N12/N16) are not direct injection.
Old Oct 7, 2020 | 11:54 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Thanks for clarifying!
homchz
Feb 20, 2018 06:49 PM
Jolio
Aug 8, 2012 10:39 AM
dab07739
R60/R61 Stock Problems/Issues
Jan 16, 2012 02:15 PM
or birdman
Classic Mini Talk
May 6, 2011 04:34 PM
Mad Cabbie
Nov 14, 2010 09:23 PM
