Supercharger Teflon chunks 2
Old May 18, 2020 | 03:37 PM
AndrewVanis's Avatar
AndrewVanis
Unlike the questionable material in this post https://www.northamericanmotoring.co...on-chunks.html
I actually have teflon chunks (slabs) in my intercooler. Also I blew a yard blower through the J pipe/supercharger and slabs came off. (And interestingly, the scroll gears and pulley moved with the air from the blower) I can see the coating missing from the scroll gears. I blew backwards through the intercooler and it seemed to clean up.
same questions:
am I now on borrowed time with this supercharger, replace it ASAP (which I wont do since this is a low-budget R53 rebuild) or it will last a while longer maybe just not as efficiently. There is no noticeable noise coming from it
Old May 18, 2020 | 04:30 PM
Eurothrasher's Avatar
Eurothrasher
Old May 18, 2020 | 04:33 PM
Minifenrir's Avatar
Minifenrir
Old May 18, 2020 | 05:07 PM
AndrewVanis
There was oil on both ends. Came out color of light molasses and viscocity of w30
Old May 18, 2020 | 06:41 PM
Oldboy Speedwell's Avatar
Oldboy Speedwell
YOWZA!
That is pretty scary looking.
Apparently the earlier M45's used an acrylic plastic coat?
Site where image came from:
http://www.thehighspeedlab.com/eaton-rotor-coating.html
Also shows later version M45 rotors with interference-fit abradable coating which is usually called teflon by most people.
I was alarmed by the severity of loss you posted and bounced around reading a few things,
lots of forum posts on the topic:
https://www.google.com/search?q=m45+..._AUoAHoECAEQAA
If I were in your situation of low-budget build, I'd just clean up the mess and possibly try to remove all the coating I could, then just run with it until I could find an 05-08 junkyard M45.
Old May 18, 2020 | 07:09 PM
AndrewVanis
Originally Posted by Oldboy Speedwell
....If I were in your situation of low-budget build, I'd just clean up the mess and possibly try to remove all the coating I could, then just run with it until I could find an 05-08 junkyard M45.
GREAT find! Thank you! I like your idea of cleaning them up tough that would require taking them out and 1) I don't know if what I couldn't get off would flake later anyway and 2) I'd likely disturb the gaskets/seals which I don;t want to buy..
I'm inclined to put a mesh screen on the intake side of the Intercooler to keep the flakes out of the intercooler and check the screen periodically.
Old May 19, 2020 | 05:59 AM
wow never seen that on the early ones. yep, remove it and find another charger or get an upgraded charger aftermarket.
Longboard110
May 18, 2020 03:39 PM
David Dennison
R58 :: Coupé Talk (2012+)
Jan 15, 2016 12:37 PM
StPeteMiniS
Oct 21, 2015 09:03 AM
Rev.Piggy
R55 :: Clubman Talk (2008+)
Mar 6, 2014 05:24 AM
Mutley MCS
Apr 6, 2008 09:34 AM
