R53 code p2096 and limp mode
Old Dec 17, 2019 | 06:04 PM
Billiemtaylor's Avatar
Billiemtaylor
I have an 06 s model started throwing code p2096 I have since replace the 02 sensors several times only to drive 5 miles and light come back recently started going into limp mode as well I have since replaced serpentine belt 02s again with ntk fuel pump and filter with no luck will be replacing injectors tomor need help to pin point the issue bc I have no clue what would be causing the fuel trim to be lean also just started throwing code p1125 but only after going into limp mode I can erase codes but p2096 comes right back after a few miles also car has been straighted piped no cat have a non Fowler in 2nd 02 and has nvidia muffler only other after market is msd coil pack dragon fire 10 2mm plug wires and ngk iridium plugs
Old Dec 19, 2019 | 12:30 PM
Billiemtaylor
Update replaced injectors drove roughly 15-20 miles no issues now back to the same thing cell on same code could I possibly need to get inpa and reset my adaptions
Old Dec 19, 2019 | 12:51 PM
RockC's Avatar
RockC
P1125 is a manufacturer specific code. A bit of research for MINI (BMW) the error code indicates a throttle position sensor (TPS) fault. The engine controller goes into limp mode because the engine controller does not believe it can rely upon the signal from the TPS.
If my info is right you are probably looking at having to replace the TPS or perhaps the throttle body. These components generally have no field serviceable hardware in them.
Old Dec 19, 2019 | 02:11 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I would get INPA an give it a try. You will be able to reset your fuel adaptations which clear your 2096 code. Plus you will be able to reset your Tps as well.
Old Dec 19, 2019 | 04:59 PM
RockC's Avatar
RockC
Given how expensive a TPS or TB is one wants to be sure of his diagnosis. If the INPA can help in this regard then oh yeah, get one.
Old May 15, 2022 | 04:03 PM
JOHN21BLACK's Avatar
JOHN21BLACK
1689 code is gone. Jan recommended to clean TB. Now I'm getting codes 1238, 0113, 0108. Jan said it was the TMAP sensor. I changed both TMAP and MAP to be on the safe side. Same codes. Drove down to RMW and Jan put is computer on my car and said I have a bad wire or broken wire in the harness. Ordered a new Harness from BMW and in the process today changing it out. Not hard to do. Hopefully this fixes the problem with those codes.
Old May 30, 2022 | 11:52 AM
JOHN21BLACK
Changed harness. Been driving car every day for last 2 weeks to work.. No codes or issues. Must have been a short with old harness like Jan mentioned.
Old Mar 26, 2026 | 08:59 AM
ED955S's Avatar
ED955S
@JOHN21BLACK , Which harness did you replaced? It fixed the P2096 code?
I have 04 MCS and got this code two days ago. I can clear it with my iCarsoft 910 and Thinkdiag TKD01 but come back after starting the car.
wojtek@pagacz.ca
Jun 9, 2019 09:22 AM
willy-mini
Apr 7, 2016 12:30 PM
JPP
Jan 18, 2016 11:50 AM
twlai
Dec 7, 2014 02:57 PM
