Timing Chain Issues
Old Nov 11, 2019 | 03:02 PM
JerryG's Avatar
JerryG
Timing Chain Issues
Hello this is my first post. I've been doing some heavy digging and cannot find info on my specific problem.
I have a 2010 Mini Cooper S N14. I just did the timing chain as I was hearing the typical harsh noise on cold start. Turns out, my upper guide had broken.
I dropped my oil pan and replaced the timing chain. After torquing down bolts and going to check timing the chain will not turn.
Let me verify. When I turn the engine by hand I have no problem (plugs are out so no compression). As I turn the engine my cams and timing chain refuse to budge.
Am I missing something crucial?
Old Nov 11, 2019 | 03:15 PM
MiniToBe's Avatar
MiniToBe
Hmmm....it's hard to tell without a video, but is it possible the crank bolt snapped? Or is it possible your using a bigger socket? Did you remove all your locking tools?
Old Nov 11, 2019 | 03:24 PM
JerryG's Avatar
JerryG
I've used 2 bolts (since stretch bolts and 1 time use). The 1st was fine after I removed it. It doesn't seem to be a broken bolt. I'm using an 18mm socket and all the locking tools are off.
Old Nov 11, 2019 | 03:43 PM
MiniToBe's Avatar
MiniToBe
Could you upload a video? If everything is tight to spec, all should be moving together or all are locked. Or the wrench lost its grip.
Old Nov 11, 2019 | 03:47 PM
JerryG's Avatar
JerryG
I will try. I'll have to edit the video for file type.
Old Nov 11, 2019 | 03:50 PM
MiniToBe's Avatar
MiniToBe
Just got an idea, drop two long straws to see if the pistons actually turn too.
Old Nov 11, 2019 | 03:55 PM
JerryG's Avatar
JerryG
I just checked with zip ties and yes the pistons move up an down
Old Nov 11, 2019 | 04:00 PM
MiniToBe's Avatar
MiniToBe
Huh...this is sooo weird! Something is definitely not sitting right!!
Old Nov 11, 2019 | 04:07 PM
JerryG's Avatar
JerryG
Here's a video
Old Nov 11, 2019 | 04:09 PM
MiniToBe's Avatar
MiniToBe
Originally Posted by JerryG
Here's a video
Not attached.
Old Nov 11, 2019 | 04:11 PM
JerryG's Avatar
JerryG
It will not upload
Old Nov 11, 2019 | 04:16 PM
JerryG's Avatar
JerryG
https://www.youtube.com/watch?v=e89n...ature=youtu.be
Old Nov 11, 2019 | 04:26 PM
MiniToBe's Avatar
MiniToBe
When you said the timing chain wont budge, is that when you try to turn it from the cams?
Old Nov 11, 2019 | 04:43 PM
JerryG's Avatar
JerryG
I can turn the cams by hand but they will not budge when the engine is turned over
Old Nov 11, 2019 | 04:47 PM
MiniToBe's Avatar
MiniToBe
Hummm...maybe at that point, the pistons hit the valves. Double check the timing.
Old Nov 11, 2019 | 04:50 PM
JerryG's Avatar
JerryG
Is there a specific way to check the timing at this point?
Old Nov 11, 2019 | 05:32 PM
MiniToBe's Avatar
MiniToBe
Spin the crank and lock it with pin. Observe the cams orientation.
Old Nov 11, 2019 | 05:52 PM
JerryG's Avatar
JerryG
The cams are set as they were when I removed the locking tool. They don't move when the crank does
Old Nov 11, 2019 | 05:54 PM
MiniToBe's Avatar
MiniToBe
Can you attach a picture of your set up.
Old Nov 12, 2019 | 10:42 AM
Lancaster's Avatar
Lancaster
It sounds like your crankshaft sprocket is not moving with your crankshaft. Your pistons are moving while turning by hand which means your bolt and crankshaft assembly are all working. If the top end is not working, the place these two meet is the crankshaft sprocket. I would check to make sure this part of the job was reassembled correctly.
Old Nov 12, 2019 | 12:46 PM
JerryG's Avatar
JerryG
I'm fairly certain this was caused by the hub. I pulled out the hub had to fight it off the timing sprocket. I checked it against the old sprocket and it seems slightly mushroomed.
I ordered a new hub from ecs. Hopefully this will solve my problem
Old Nov 13, 2019 | 09:31 AM
oldbrokenwind's Avatar
oldbrokenwind
Here's a pretty good procedure for replacing a timing chain --- https://www.newtis.info/tisv2/a/en/r...aft/1VnY7d2Xnh browse thru it to ensure you've done all the right stuff and in the correct order. It also has a method to verify timing is correct after initial setup.
soulala0593
Jul 6, 2019 06:54 PM
IsaacinPhilly
Mar 18, 2019 08:00 AM
Jul 19, 2015 10:15 AM
vinster
Feb 20, 2015 04:41 PM
MiniPOLACK
Jan 10, 2010 01:14 PM
