2007 MCS Stalls after filling up with Gas
Old Nov 3, 2019 | 05:14 AM
Cenla Mini's Avatar
Cenla Mini
I continue to have problems with my 2007 MCS after I fill up with gas. I've seen with several different models of cars (not Mini) where there's a purge valve that can be replaced and it fixes this problem. I cannot find a purge valve in the Mini on either Real OEM or other parts sites.
I can rev the engine and get it idling at around 2K for approx 30 seconds to 1 minute and it'll stay running...then I'm on my way. It's annoying but not keeping me from driving it.
Has anyone else experienced this problem?
Old Nov 3, 2019 | 05:26 AM
Cenla Mini's Avatar
Cenla Mini
Ha...never mind...I couldn't find a purge valve because it's not called a purge valve on the 2007 MCS...it's a MINI Fuel Tank Breather Valve with Hose.
I thought I had searched through all the related forum threads but when I posted this today I saw related posts at the bottom of the page...found another thread where the user called it a purge valve but had a link to the part number..
Correct part/number on Pelican Parts is: 13-53-7-543-285-BOE
Old Nov 3, 2019 | 08:52 AM
MVPeters's Avatar
MVPeters
Before you spend $!00................!
Next time you fill up, make sure the pump nozzle is in as far as it will go & then stop when the pump first shuts off.
I have a feeling you're filling the evap vent hose.
Old Nov 3, 2019 | 11:20 AM
Cenla Mini's Avatar
Cenla Mini
Thanks for the suggestion...I tried that first..have never had any cars do this and I never top off the gas. I bought this car with known problems and did a complete head gasket, timing chain, vacuum pump, new oil housing/heat exchange gaskets, turbo cooling lines etc...Oh...also changed the fuel filter but have had this happen time and again now after 4 - 5 fill-ups.
Old Nov 5, 2019 | 06:00 PM
mini-is-for-me's Avatar
mini-is-for-me
It is a solenoid right? That's a pretty big hunk of change to dish out. You could test it before replacing it.
Old Nov 6, 2019 | 04:54 PM
Gearscout's Avatar
Gearscout
Deleted...saw you had changed the fuel filter!
Old Nov 6, 2019 | 06:23 PM
Cenla Mini's Avatar
Cenla Mini
I'm not sure how to test it...but ordered the part so hopefully......
j-gregs
Feb 15, 2023 07:41 AM
67/327
Jun 7, 2020 11:38 AM
Fred Heiler
Jan 28, 2020 03:41 AM
Cenla Mini
Oct 6, 2019 07:35 AM
Yakatak
Factory JCW Talk (2009+)
Jan 1, 2013 02:22 PM
