09 Mini wont start
Old Oct 27, 2019 | 01:31 PM
sunny8088's Avatar
sunny8088
09 Mini wont start
I have 09 mini with 132xxx miles
Brand new battery
Whn I push to start RED service ilight comes on
help
Old Oct 27, 2019 | 06:16 PM
AZdsrt's Avatar
AZdsrt
You need to pull the codes, could be a zillion different things.
Old Oct 27, 2019 | 06:27 PM
sunny8088's Avatar
sunny8088
Thanks , looking for code readr I can borrow in zip code 32746
Old Oct 27, 2019 | 06:29 PM
AZdsrt's Avatar
AZdsrt
Take it to Autozone (or similar), they will pull the codes for free..
Old Oct 27, 2019 | 06:34 PM
AZdsrt's Avatar
AZdsrt
Oops, my bad. I just realized it won't start making that a challenge.
Old Oct 28, 2019 | 06:24 AM
sunny8088's Avatar
sunny8088
I am planing to order one from Amazon, quick question.
For the code reader to work that car has to be ON (running) ??
Old Oct 31, 2019 | 07:01 PM
Otay's Avatar
Otay
It doesn't have to be running but it does have to be on.
Old Nov 12, 2019 | 05:35 AM
sunny8088's Avatar
sunny8088
I did order a blue tooth from Amazon (OBD) , but it does not show clearly what is wrong , gives bunch of codes & numbers
Still a start issue, after 5 to 8 attempt it starts, All lights work fine
Old Nov 12, 2019 | 06:27 AM
Andy_S's Avatar
Andy_S
Post all the codes here, and somebody can probably help.
Old Nov 13, 2019 | 04:35 AM
sunny8088's Avatar
sunny8088
These are the codes I got
Old Nov 13, 2019 | 05:17 AM
pluffmud's Avatar
pluffmud
Your reader seems to be a generic OBDII and will not give you the specific codes - it seems to be just providing a status report. In my experience (maybe just my idiot local autozone), they do not usually have the correct reader to pull BMW/Mini codes.
Codes should read in numeric values. IDK if a 2009 requires it, but some Minis require reprogramming when a new battery is installed.
Old Nov 13, 2019 | 05:19 AM
sunny8088's Avatar
sunny8088
Thanks, my problem is car wont start (9 out of 10 times) so can not take to auto parts store, and definitely want to avoid dealer.
Old Nov 13, 2019 | 05:23 AM
pluffmud's Avatar
pluffmud
Do a quick Google search or thread search here to see if battery programming might be the issue. Some members with more knowledge will prob chime in today - maybe there is a hack to get her started. Good luck!
Old Nov 13, 2019 | 05:24 AM
sunny8088's Avatar
sunny8088
Thank you Sir, I did install NEW battery
Old Nov 13, 2019 | 05:50 AM
pluffmud's Avatar
pluffmud
Per several threads here, if your Mini has the IBS module (little square box attached to the negative battery terminal) it will need reprogramming.
Old Nov 13, 2019 | 09:03 AM
Andy_S's Avatar
Andy_S
That's the Torque (or Torque Lite) app. Within the app menu (the gear icon) select Fault Codes... then Show logged faults. Screenshot those, or write down the faults given. You might also do the same with Show pending faults.
Old Nov 13, 2019 | 01:07 PM
shanksamillion's Avatar
shanksamillion
If you’re trying to pull codes
Try ordering the Schwaben nmini/bmw specific scan tool from ECS Tuning. It will pull all codes obd and mini specific. Also I could be wrong but not registering new battery will not cause it to not start. It will just fry your new battery and it may or may not last very long. Anyway try to get some codes
Old Nov 18, 2019 | 10:22 AM
sunny8088's Avatar
sunny8088
OBD Pictures
Old Nov 18, 2019 | 10:27 AM
sunny8088's Avatar
sunny8088
Obd
Pictures
Old Nov 19, 2019 | 11:10 AM
sunny8088's Avatar
sunny8088
Any suggestions ?
blackprophet
R55 :: Clubman Talk (2008+)
Jul 31, 2016 12:53 PM
Camilo A Londono
Oct 31, 2015 03:00 PM
ccain
Jan 7, 2013 05:45 AM
Sticky
Apr 1, 2008 04:53 AM
soul embrace
Dec 4, 2007 10:53 AM
