Loose headliner - what to do?
Old Jul 9, 2019 | 05:52 AM
JAB 67's Avatar
JAB 67
2004 R53, 160K. I just noticed that where the headliner meets the windshield it is starting to come loose. What is the best way to fix it?
Old Jul 9, 2019 | 05:57 AM
Marc08EX's Avatar
Marc08EX
I’m also curious as to what is recommended as my headliner on my JCW is coming loose.
From my quick research, this is what I was planning to do unless there’s an easier way
Old Jul 9, 2019 | 07:24 AM
Blue R50's Avatar
Blue R50
Basically, there is a layer of foam between the fabric and the shell that is failing. The new fabric comes with the foam attached and so you need to reupholster it. I do my own and it's not that hard, but have not done one in a MINI yet, so I can't tell you the specifics. It is a common problem and they fail in 5 to 15 years depending on where you live and how hot it is.
Old Jul 9, 2019 | 01:50 PM
Clean the old one off and replace it. I have done it on BMWs before its a pain to clean off the old stuff, not to hard to roll out and glue the new fabric. New fabric is pretty thick and foamy a little from those universal headliner shops.
Or upgrade to the anthracite factory headliner : https://www.northamericanmotoring.co...o-sunroof.html
Old Jul 12, 2019 | 06:13 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I replaced mine by myself. Not real hard. You will be out of pocket around 60 dollars for fabric and spray adhesive. I bought the fabric on ebay.
Old Jul 14, 2019 | 07:07 PM
R55S's Avatar
R55S
At this point you’re going to want to replace it. I prefer to have the headliner board out of the car and strip it, get it completely clean. Then use 3M 74 clear (personal preference over orange) spray adhesive on both the material and the board in consistent coats. I like to work with the headliner board facing up on table, having two people is handy if this is your first one.
carveitup
Feb 17, 2017 02:15 PM
k_h_d
Suspension
Apr 7, 2013 01:37 AM
Claudia
Aug 24, 2010 08:05 AM
