What other maintenance while servicing SC?
Old May 27, 2019 | 10:14 AM
peterro's Avatar
peterro
Hi all,
What would be a good list of maint items while servicing the SC? I was thinking of replacing the water pump and crank positioner o-ring. What else is recommended? Since I'm in there, it's a good time to do the hard to get to items.
Old May 28, 2019 | 03:11 PM
ItsmeWayne's Avatar
ItsmeWayne
Check to make sure the low speed is working on the coolant fan, as they always seem to go out. Now is the time to replace it, if it is dead!
The ac clutch can be replaced if the ac is not working a (turning on) replace dryer tank, if ac is not working and maybe a compressor if it is charged and not working.
Check to make sure the vacuum hoses are all attached and make sure the blow off valve is working. Quite often the spring or diaphragm go out.
Old May 28, 2019 | 03:31 PM
Tgriffithjr's Avatar
Tgriffithjr
Clean the throttle body.
venkp
May 14, 2011 08:06 AM
CARdiac
Dec 30, 2009 09:30 AM
isykal
Jul 26, 2004 01:01 PM
dominicminicoopers
South West
Nov 26, 2003 10:18 PM
RichardCrofts
Apr 15, 2003 08:08 AM
