Should I change the Valve Cover?
Old Apr 14, 2019 | 07:36 AM
jjcsnlynn's Avatar
jjcsnlynn
After reinstalling the head from valve damage in my new to me 07 MCS I started getting P1497 codes as the engine would come back to idle.
I installed the caps on the passenger side of the valve cover and the codes went away. I also installed an OCC on the drivers side.
My question is since the code was on the passenger side and its now capped off should I still change the valve cover?
Old Apr 14, 2019 | 08:54 AM
I like mini clubman's's Avatar
You've solved the problem. If you put on a new cover it will shortly do the same thing. This is a common problem for the N14 valve covers.
Billiho
Jun 3, 2019 05:44 AM
Gabe3
Feb 25, 2019 01:24 PM
minnella
Feb 4, 2016 02:56 PM
toddcann
Mar 22, 2014 10:33 AM
discodan
Apr 22, 2008 01:16 PM
