2005 MCS - P0128 - already replaced thermostat
Old Mar 8, 2019 | 09:30 AM
BTRMayfair's Avatar
BTRMayfair
2005 Mini Cooper S (R52/53-BMW Gen 1)
P0128 Code -- "too long to achieve operating temperature"
When first got call last year -- did laundry list of typical preventative maintenance things: suspension (ball joints/struts/bushings/etc) ... typical oil leaks... serviced supercharger... including REPLACED THERMOSTAT.
But now getting P0128 Code -- reset -- goes away -- comes back in not much time -- troubleshooting so far:
  1. Pulled thermostat out and checked it in pot of water on stove -- it opens/closes as should. Stamped with temp 91C - assume that's correct temp for '05 MCS
  2. Monitored temp on scanner -- gets up to 215-217F operating temp -- in what appears to be fair amount of time -- not sure how long mini thinks is "too long" to achieve operating temp.
Car is not overheating, etc -- check engine comes on for too slow to temp only -- I realize this is for efficiency goals.
Only other changes on car that I can think off that might even remotely impact coolant temp:
  1. Swapped supercharger pulley from my JCW -- so water pump is now running faster -- BUT if thermostat closed -- assume water pump speed would have no impact on taking longer to get to operating temperature.
  2. Changed out fan relay with Detroit Tuned Fan Relay KIT -- the one to fix bad diode impacting low speed fan settings. Low speed fan did not come on properly before -- wasn't running with car idle and A/C on.
Anyone have any other ideas to try around resolving P0128?
Chris
Old Mar 9, 2019 | 05:20 AM
rondayvous's Avatar
rondayvous
Is it possible the temp sensor is flaky and the temp is fine, just not getting a good signal?
matthewbrakeii
May 13, 2021 08:39 AM
tkenupp
Jan 31, 2018 07:41 AM
Pneumo
Feb 9, 2017 08:17 PM
igby20
R57 :: Cabrio Talk (2009+)
Sep 22, 2013 05:47 PM
Mindspin311
Sep 10, 2012 12:05 PM
