Possible blown exhaust manifold gasket
Old 01-14-2019, 07:17 AM
portedbuckle's Avatar
portedbuckle
portedbuckle is offline
Hi everyone,
I am hearing a somewhat quiet hiss that seems to be coming from the exhaust manifold area. The car runs really well, no issues at all, and I don’t hear the his while driving. I can only hear it with the car running at idle and the bonnet open. I also do smell exhaust from the engine bay as well (just slight). I want to make sure that this is indeed the issue before I pull the gasket. How might one go about tracking down the leak? I’d go have it smoke tested, but having done all the work on my car for the last 10 years, I do pride myself in doing it at home. Any help is appreciated! Thanks!
Old 01-14-2019, 07:55 AM
Tgriffithjr's Avatar
Tgriffithjr
Tgriffithjr is offline
Is it a constant hiss or does it fluctuate with throttle response? I don’t recall ever hearing a hiss from an exhaust leak. Usually it’s a putting sound. A hiss is usually a vacuum leak. Get a mechanics stethoscope and listen around the engine. You will be able to pinpoint the source pretty easily.
Old 01-14-2019, 08:01 AM
portedbuckle
Thanks! I don't have someone around to help check it with different throttle settings. The engine seems to be holding a strong vacuum however. I suppose it could be the valve cover gasket, but I just replaced that. Not sure what the smell would be about though. I'll grab a stethoscope and see if I can't pinpoint it that way.
Old 01-14-2019, 08:55 AM
portedbuckle
Update. Best I can tell it is coming from the power steering reservoir. That is the only suggestion of a hiss I got with the stethoscope. I guess maybe the cap is leaking pressure which I am not sure is by design or not.
Old 01-14-2019, 10:00 AM
JAB 67's Avatar
JAB 67
JAB 67 is offline
I don't think that the power steering reservoir is pressurized, unlike the coolant expansion tank.
Old 01-14-2019, 01:04 PM
Tgriffithjr
Move the stethoscope around until you’re sure you found the loudest point. The coolant tank is right next to to power steering reservoir.
Old 01-16-2019, 01:47 PM
portedbuckle
You guys were right. It’s not the power steering reservoir and I checked the coolant reservoir and it’s not coming from there. It does seem to be coming from the exhaust somewhere. I haven’t had a chance to let the car cool and pull the exhaust manifold heat shield, but that’s next. Hopefully it’s just the gasket, but I’ve wanted a header for a bit.... just didn’t want to spend the money right now. I’ll update when I can.
Old 01-16-2019, 05:20 PM
ItsmeWayne's Avatar
ItsmeWayne
ItsmeWayne is offline
Usually on the r53, the coolant tank splits on the seam and causes a hiss and can make your engine overheat and cost you big repairs.
Old 01-17-2019, 07:51 PM
wdietz186's Avatar
wdietz186
wdietz186 is offline
You could be hearing the noise from a cracked catalytic converter. It cracks at the upper weld on the cat, it is under a shield and you can't really see it unless you remove the header/cat pipe. It isn't that hard to do if you get the car up in the air. I welded mine back together and it seems to be holding up pretty well. The noise will get progressively louder until it comes completely apart then it is LOUD and it will drive you out of the car.
skimm343
07-28-2020 07:27 PM
B.Mank
06-16-2015 04:55 AM
Gemusan
06-07-2007 07:59 PM
faustk
02-13-2006 06:48 PM
Quick Reply: Possible blown exhaust manifold gasket
