R50/53 Exhaust manifold gasket question
Old Jun 8, 2013 | 01:20 PM
B.Mank's Avatar
B.Mank
Looking at the new OEM exhaust manifold gasket, one side of the gasket is flat and on the other side is raised around each exhaust port.....Does anybody know if the flat side or the raised side goes towards the head??? or does it even matter ???.............Thanks
Old Jun 9, 2013 | 03:21 PM
AlexQS's Avatar
AlexQS
Bump
I bet someone knows
Old Jun 9, 2013 | 04:35 PM
AlexQS's Avatar
AlexQS
Okay,.. I looked it up. I was expecting some lettering like this side facing head... Nah
My book says this ".....installation is reversal of removal, noting the following points:
Apply some anti seize compound to the manifold bolts
Always replace the manifold gaskets with the raised edges of the gasket facing toward the manifold
Exhaust manifold fasteners: 18 foot pounds
Note: I was surprised my book did not mention a particular order to tighten the bolts in. Me, I would tighten them in some sort of X Patern
just to be safe
Old Jun 10, 2013 | 08:35 PM
B.Mank's Avatar
B.Mank
Thanks for that follow up! On that note, I couldnt find an answer anyplace and already installed it with the edges facing the head not the exhaust manifold ;(............ No leaks,.....YET???? All seems fine for now
Old Jun 11, 2013 | 09:43 AM
AlexQS's Avatar
AlexQS
If you didn't use anti-seize then if it were me, I'd get a new gasket and redo it very soon. You wouldn't want a headache later if it starts to leak, and then the bolts are stuck too.
Old Jun 13, 2015 | 12:13 PM
clyde72's Avatar
clyde72
Replacing Exhaust Manifold Gasket 2002 R53
just to be safe
Thanks for finding/posting this. All my Bentley manual basically says is installation is reverse. I did not notice how my old gasket was oriented. Also I could not tell by looking at the old one or the many pictures I took during dis-assembly.
Old Jun 14, 2015 | 08:20 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It doesn't say anywhere, but I put it up side toward the head. So you'll be fine.
Old Jun 15, 2015 | 10:05 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
just to be safe
The tightening torque's listed in the Bentley Manual list the exhaust manifold to cylinder head 18ftlb, exhaust system to exhaust manifold 44ftlb, and then heat shield to cylinder head 10ftlb. I'd assume to maybe go in that order? Not sure if mine is the older version, but for the gasket it just says, "replace exhaust manifold gasket" and doesn't say in any particular way. So thanks for posting that!
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 15, 2015 | 12:19 PM
Good thread here , CooperSAZ noticed that the flared outside goes towards the rear of the vehicle.
" The old gasket will most likely drop away as well. Pick up and remove the gasket. Note the way it is placed on the engine. Make sure the flared out side is facing the rear of the vehicle. "
https://www.northamericanmotoring.co...y-blk-r53.html
http://www.ecstuning.com/Search/SiteSearch/11621174968/
https://www.northamericanmotoring.co...der-bolts.html
Old Jun 15, 2015 | 04:40 PM
jamez's Avatar
jamez
Sorry, I'm confused... I've read from the top, and it appears to me that there is conflicting info here (or perhaps I don't understand the terminology) Way, ECS, et all... Can you once again confirm which way the raised side goes towards?
Is the "manifold side" the engine side (front of car) or the pipe side (rear of car)?
Old Jun 16, 2015 | 04:55 AM
Based on what CooperSAZ noticed the "old gasket was flared side to the rear of the vehicle" , manifold side rear on the car.
ShadyCoop
Aug 24, 2015 06:05 AM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
