P0697 code after valve cover eplacment
Old Dec 15, 2018 | 11:11 AM
hockeydad51's Avatar
hockeydad51
Ok so long story short I repelaced my valve cover and inadvertently broke off the gound wire. I attached a spade terminal to the ground wire, reset the codes it was throwing (P00012). Now when I try to start it throws a P0697. My code reader still reads the codes so I assuming the ECM is still okay but I'm trying to figure out where to go from here. Is it possible the splicing I did on the ground could cause the code to be thrown? If so, does anyone know what guage ring terminal connector I need to properly fix this?
Old Dec 16, 2018 | 03:37 PM
mkov608's Avatar
mkov608
Which ground wire? Yes your repair job could cause a problem. Did you check the repair for continuity?
P0697 is a open reference voltage (CAN 5 VDC) signal to a sensor. Check the connections for the two cam position sensors on the right side of the valve cover.
Old Dec 16, 2018 | 04:11 PM
hockeydad51
It was the coil ground to the valve cover. I'll get a tester and check it tomorrow to make sure the repair is good. I checked the one cam sesnor connection that I had to disconnect to change the cover. Right now I'm just getting cranking but no start.
Old May 28, 2020 | 12:53 PM
Adam Smith's Avatar
Adam Smith
Did you fix it?
Did you get this fixed? If so, what was the solution?
jjcsnlynn
Apr 14, 2019 08:54 AM
Gabe3
Feb 25, 2019 01:24 PM
Howster
Jan 15, 2019 06:02 PM
DuffyMule
Jul 7, 2017 10:27 PM
Sstrickstein
Jul 15, 2016 09:56 AM
