R56 Code P2B64
Old Jul 13, 2016 | 06:53 PM
Sstrickstein's Avatar
Sstrickstein
Code P2B64
I have a weird issue. Seems After I come down to a stop light I get a little hiccup. I plugged in my Accessport and is shows I have a code P2B64. This is an intake manifold leak. I pulled the airbox and checked all connection. I removed the MAP sensors and cleaned and replaced them. I removed my valve cover and checked and cleaned that and its seals. All good. I even used a hose to check the PCV in the valve covers and they flap and close as they should. This only seems to happen at idle. Doesn't seem to effect anything yet. I do however notice a sound like whistle after I shut off the car. Sounds like a ballon deflating. I checked all hoses for leaks and nothing there. Even the sound generator. Suggestions?
Old Jul 13, 2016 | 07:43 PM
Sstrickstein
Could this be a bad PCV internal to the valve cover?
Old Jul 14, 2016 | 12:38 PM
timski's Avatar
timski
New valve cover gasket. Corrected P2B64 for me 2011 JCW
Old Jul 14, 2016 | 01:09 PM
Sstrickstein
I replaced the valve cover and cleared the codes. The noise is now gone. I believe that solves the problem
Old Jul 14, 2016 | 01:13 PM
timski's Avatar
timski
Did I actually help you or you had this idea
Already? Ha.
I like to think I'm helping someone out there. Ha
Old Jul 15, 2016 | 07:38 AM
Sstrickstein
It was suggested by several sources including you.
Old Jul 15, 2016 | 09:56 AM
timski's Avatar
timski
Awesome let us know after 100 miles.
randeez
Apr 1, 2016 12:11 PM
Rchitct
Mar 28, 2016 05:51 PM
BMBULBE
Mar 18, 2016 10:35 AM
PelicanParts.com
Mar 16, 2016 12:37 PM
