Software upgraded to 39.2 issues on MCS
Old Nov 23, 2004 | 02:12 PM
  #101
Herby74's Avatar
Herby74
I had V39 done two weeks ago because my SES warning lit up and the engine started sputtering. I still wasn't happy, but after I reset the ECU this weekend things appeared to be fine. Unfortunately, the engine has begun sputtering again and I have an appointment on Monday to have it thoroughly checked out by one of their techs who is really super.....they're actually going to give me a loaner for the day! The tech told me that I'm their first V39 reflash to come back with a problem. I'm looking forward to their findings.
Old Nov 23, 2004 | 02:47 PM
  #102
Minirox's Avatar
Minirox
Ok here's the rest of the story: V39 corrects a fault code in the emmission program. It's supposed to be v38 with this correction.If you live in a state or city that has you emission test before registration renewal. You will need to get the up date or your car could fail.(Modern technology) they plug it in, if a fault code shows up you fail. Mini is coving there butt by the recall so you can't blame them if it fails. How many of you who are dissatisfied with the upgrade have after market software? Just a thought.
I live in an area where emission testing is not required. I also have aftermarket software and my car runs fine so I have no intention of upgrading.
If you live in an area like mine(emission testing not required) and you take your mini in for service and don't want the upgrade make sure the service manager knows you don't want it. So they don't just load it.
Old Nov 23, 2004 | 02:59 PM
  #103
rajron's Avatar
rajron
I needed emissions testing to register the car in my city because I bought the car out of state, indecently the smog checks failed so the technicians just gave me my certificate anyway because they said it was a new car and they were not familiar with it. In two years I will have to go through the emission testing again and will need the ECU upgrade, hope it’s all resolved by then. Read in other thread, yo-yo, and a lot of the people there who had the V39 thought it was an improvement over the other ECU upgrades?
Old Nov 23, 2004 | 03:10 PM
  #104
dominicminicoopers's Avatar
dominicminicoopers
I've had two other version of software on my MCS. v36 and one prior to that (don't remember the number--it was being put into Jan 03 build cars). Neither of these had the "herky-jerky" feeling, althought the first one did have the 1st Gear stumble. As a matter of fact they felt smooth as glass in most all throttle positions and deltas of throttle. Much like a BMW designed car should feel. However now with the herky-jerky feeling of 39.2, it feels much worse than the software on my wife's 2002 Neon. The Neon had been in 4 times for software related issues that they couldn't solve. But alas, that's another story. What really sucks is the Neon drives better than the MCS now... and that really sucks because it's a 9.9k car as compared to a 23k car! I'd like to get back to v36 as it was smooth as glass!
BTW, I do not have aftermarket software. Maybe aftermarket might "fix" the issue, but why spend $800 of my hard earned cash to fix MINI's mistake?
Old Nov 24, 2004 | 09:43 AM
  #105
CoryB
Can you reveal your source on this? It seems like a big step backwards for MINI as v.38 corrected - for the most part - many other problems (cruise control, yo-yo, etc.) So why would they backtrack to v.36 and it's known problem history?
Originally Posted by Minirox
Ok here's the rest of the story: V39 corrects a fault code in the emmission program. It's supposed to be v36 with this correction.
Old Nov 24, 2004 | 09:59 AM
  #106
Herby74's Avatar
Herby74
This V39 and emissions control stuff is starting to get to me. After half a mile this morning, my SES light went on again and I had some serious sputtering and loss of power. I went straight to the dealer, fortunately only ten miniuites away, and had to leave it there. They may be able to start looking at it today, but probably not until Friday. No loaner this time.
Aahhhhhhh!!!!!
Old Nov 24, 2004 | 10:26 PM
  #107
Minirox's Avatar
Minirox
__________________________________________________ _____________
posted by CoryB
My Bad V 38 with changes. My info was from the teck at Mini. I have 36 which worked fine on my 03 MCS. Since then I've added Dinan s3 software. Im going to stick with what works.No 39 or 40 what ever else they come up with. Edited original post Thanks
Old Nov 25, 2004 | 08:52 AM
  #108
CoryB
posted by CoryB
Ah! Correction noted. Thanks!
Old Nov 25, 2004 | 09:19 AM
  #109
Ryephile's Avatar
Ryephile
Herby - stop being so nice to your MINI - next time it starts sputtering, cram the gas to the floor teach it a lesson!
Old Nov 25, 2004 | 09:36 AM
  #110
Herby74's Avatar
Herby74
Ryephile......I've tried that, but the car actually talks back and tells me that it's going to blow if I don't take my bleepin' foot off the pedal. I hope that the Mini tech is able to teach it some better manners! Will report back.
Old Nov 25, 2004 | 10:03 AM
  #111
Ryephile's Avatar
Ryephile
Is your car still stock and/or warrantiable? If so, let it blow itself up! There is no good reason the ECU should let that happen, but if something is wrong with MINI's software, then it's totally their problem! That should give the [usually stupid] MINI techs something tangible to work with
Old Nov 26, 2004 | 12:16 PM
  #112
tagger99's Avatar
tagger99
Exactly how do you do the reset?,after going thru the steps to "log i-on" and scrolling to number 21.0 do you hold the button for 3 seconds and that preforms the reset, is there a confirmation that the reset has taken place?
thanks
Tom
Old Nov 26, 2004 | 04:26 PM
  #113
Ryephile's Avatar
Ryephile
lol - yea the gauges will reset (looks like they're freaking out), and ALL your lights will flash, and your trip odo will reset.
Old Nov 26, 2004 | 05:15 PM
  #114
MINISPIDER's Avatar
MINISPIDER
I took my car to the dealer for the recall letter i've got, and he advised me not to do it. He said it may mess up my current settings and just to leave it alone, since the recall is nothing serious and is just to make the techs life easier when diagnostic a problem.....He put my key in the key reader and told me I'm better off without it..so I took his advice and left running out of there. My car is been running great since the day I picked it up at the dealer, may be 'cause I have a JCW and the software is different?....no complains here ...(knocking on wood)
Old Nov 27, 2004 | 02:21 PM
  #115
BSQ's Avatar
BSQ
well, just figured I'd add my experience to this nightmare thread. I went in for my 10K service on Wednesday. I checked-in a perfectly running March 04 MCS, that has had not a single problem. NOT A SIGNLE ONE! I came home with an 04MCS that feels like it's gonna stall any time I've at a long signal. Within 3 hours I was back at the dealer listening to their reasons why I was experiencing this, and in no uncertain terms telling the service rep what he was telling me what a crock of you know what. What angers me most is I specifically told him I've had none of the issues most people report with my car ... and he found that incredibly hard to believe. READ MY LIPS!
Oh well, at least reading this thread gives me something to try and see if it helps ... otherwise, I do believe they will be hearing from me quite frequently.
Siiiiiiiiiiiiiiiiiiiiiiiigh.
Old Nov 27, 2004 | 03:46 PM
  #116
Xman's Avatar
Xman
Anyone from MINIUSA would dare to comment on this issue.......PLEASE !!!!
Old Nov 27, 2004 | 03:58 PM
  #117
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
so far i have not had to many problems with V39. the car feels like it has more power and i love the way the cruise control works now! (that was from the V38 fix that i never got) i do get a strange idel every now and then if i sit too long. it has never happened at a light yet. once it was in my drive way, and i just let it go to see if it would stall or be o.k. a few seconds of shutter and the car was able to catch up on it's own and smooth out. normally i jab the gas a bit and it's fine. i would say it's only happened 3 or 4 times since i have had V39. it's shouldn't be there, but over all it's not too bad to deal with. the last tank of gas came to be 26.79 miles per gal. i am normally up around 27 or 28. but it did seam like this tank was going to go up in miles per gal. i had 250 miles on it already before it hit the half way mark. maybe i had a bit of a hevy foot that day. i'll keep an eye on it and report back later.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
  #118
mtrspt5's Avatar
mtrspt5
Willi have to disconnect my Unichip first and then do the reset or can I do it with the Unichip in the system?
Old Nov 27, 2004 | 04:19 PM
  #119
MSFITOY's Avatar
MSFITOY
So what's the biggest risk of having your emission warranty voided by not upgrading to V39? The loss of coverage for the catalytic converter?
Old Nov 27, 2004 | 06:52 PM
  #120
Xman's Avatar
Xman
mtrspt5,
I called Unichip to inquire about that exact same question, and they told me that we don't need to disconnect it before the Dealer flash the new software.
Old Nov 27, 2004 | 07:19 PM
  #121
Aqualung's Avatar
Aqualung
Like agokart, no probs (touch wood) since this past Tue. I just filled up and got 27.2 mpg, which is about 1-2 mpg higher than my running avg. I have only seen 28 mpg or so once since getting my car last spring.
And, have finally been able to use the cruise control, only seeing a 2-3mph variance, before it was totally useless. Still not as "tight" as my Honda CC, that barely moves on hills, etc.
Old Nov 27, 2004 | 07:58 PM
  #122
1996 328ti's Avatar
1996 328ti
I think I have v38 right now and the car is in the shop for the recalls, new sunroof, dash rattle, intermittent headlight module, runflat and DSC fault and I don't remember the other 1/2 dozen things. I assume I will be getting the latest version software. But I swear, the car always seems OK for a week or so then relearns its nasty habits.
Old Nov 27, 2004 | 08:34 PM
  #123
mtrspt5's Avatar
mtrspt5
Originally Posted by Xman
mtrspt5,
I called Unichip to inquire about that exact same question, and they told me that we don't need to disconnect it before the Dealer flash the new softare.
Old Nov 28, 2004 | 06:43 AM
  #124
Aqualung's Avatar
Aqualung
plus, I'm chirping my wheels in 1st, w/ DSC on...didn't seem to do this as much before...will have to adjust my takeoff routine....
Old Nov 29, 2004 | 05:58 AM
  #125
BSQ's Avatar
BSQ
I see to be doing that now too. I figured it was just my leadfoot. Okay, so now one complete tank of gas later, around town my MPG dropped from 26 to a dismal 22mpg. Highway driving still seems to be steady at about 33mpg. 500 miles later, and the car is still quite rough on idle. As others mentioned enough for passengers to comment "what's wrong with your car?"
Oh yeah, just for kicks, this morning I called Mini USA to see what they'd say about this little issue. Usually most helpful folks, it seemed like I interrupted the person I talked with from getting his morning coffee. With regard to the emissions recall work, I'm told they've not heard of a single problem.
My clock too, switched to 24 hour time. Oh how I hate having to think to tell time!
