Any answers on specific recalls for early R56S'
Old Nov 1, 2018 | 04:50 PM
Tylerkun's Avatar
Tylerkun
I have a 2008 S with just under 79k miles. I bought it used about a year ago. About 3-4 months I had a couple issues pop up. I have an issue where when I give it full throttle for longer than about 4-5 seconds, it goes into limp mode. Under normal driving conditions nothing happens and it drives perfectly fine. I also have a P0420 check engine code. I don't know if the issues are related, but I figured it'd be worth adding.
I've changed both O2 sensors, changed the downpipe gasket, and I've also inspected the diverter valve and it's in good shape. I've even unplugged it and verified the electronics were working.
I've check for open recalls and things, but there is nothing open for my VIN. There also seems to be no previous work history for anything. This car was built in January of 2008 so doesn't that put it right in the territory of the timing chain issues as well? I feel like there should be more information readily available for instances like this.
I would take it to Mini to ask, but the closest dealership is about 2 hours away. I do have a BMW near me, but they've told me they don't touch Mini's. Can anyone guide me in the right direction with anything? I've seen other talking about the warranty being upped to 100k miles, but I can't pinpoint exactly what models that happened to.
live in California and my annual smog check is coming up. Sadly with the engine light on it will not pass causing my registration to be invalid. I'm trying to figure all this out and some guidance would be awesome.
Old Nov 2, 2018 | 08:53 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
See this thread for how to look up recalls, TSBs, etc.: https://www.northamericanmotoring.co...-and-more.html
Also here: https://www.northamericanmotoring.co...on-issues.html
Old Nov 3, 2018 | 08:38 AM
Minidogger's Avatar
Minidogger
Suggest buying a scanning tool. Then you will have some good information to act upon.
Old Nov 4, 2018 | 12:44 AM
Tylerkun's Avatar
Tylerkun
Thank you for the links! I really appreciate that!
Old Nov 4, 2018 | 05:18 AM
vetsvette's Avatar
vetsvette
Moderator
You'll find that Mini doesn't like the word "Recall". They'll call it a performance/service enhancement or it'll be covered by a TSB. Sometimes you will have to show the dealer proof of a TSB because sometimes it seems they're not issued to all dealers. The only time they'll issue a recall is if the NTSB forces them too. Usually only for safety items.
wxviewer
Oct 29, 2022 05:46 PM
Joeygonz
May 26, 2017 03:50 PM
MiniGSport
May 19, 2010 02:14 PM
lava
Jul 11, 2007 06:25 AM
rob_lewis
Sep 25, 2003 09:53 AM
