Rear brake issues
Old Jul 18, 2018 | 04:14 AM
MikeR6453's Avatar
MikeR6453
Rear brake issues
Has anyone else had problems with their rear brakes?
I changed my pads awhile back. After a few mths I was starting to get some squealing so I went to look at them again. I had alot of brake dust buildup on my right side while the left was pretty damn clean. That righ there seemed pretty damn strange to me. When I went to change pads I did passenger and they were pretty worn down and needed changing. However the drivers side had a whole lot of pad left.
wondering if anyone else has had this problem before?
I havent checked the handbrake cable and not quite sure what to look for on that. And the slide pins are new when I put them on.
Any ideas on where to start?
Old Jul 18, 2018 | 04:21 AM
Whine not Walnuts's Avatar
Whine not Walnuts
You did lube the glide bolts? I also make sure the slot that the tabs move in is smooth and apply some copper antiseize.
Old Jul 20, 2018 | 06:42 PM
rwkeating's Avatar
rwkeating
I had what you describe happen on my 2006 MCS. One side of the parking brake cable was stuck and holding the brake on that wheel. It was obvious when I lifted the rear of the car, with the parking brake off, one wheel spun freely and the other didn't. Using a screw driver as a lever I was able to get the brake off. What happened was the return spring couldn't overcome whatever gunk/rust was holding the parking brake cable in place.
I ended up lubing the cable and it works now. I don't use the parking brake when the car is going to be sitting for a few days as I am sure it will seize up again. I make sure to use it when I can for relatively short periods of parking just to keep it moving. The real solution is to replace both cables. They are just too old now.
trailrated
Dec 13, 2021 09:10 AM
mathewkhng
Mar 17, 2021 04:15 AM
Daft_R53
Jun 6, 2020 08:34 PM
marc0011
Sep 10, 2015 10:04 PM
Neufusion
Nov 10, 2009 04:44 PM
