60k Cam failure
Old Jun 25, 2018 | 07:26 AM
mauls's Avatar
mauls
60k Cam failure
Hey guys, new here and working on my first mini for a friend... what a joy! Anyways car only has 60k miles on it and I was repairing a blown head gasket and cam across an ate up cam! I was curious if you could point me in a direction to find a stock replacement. I've googled and Ebay and can only find aftermarket cams. This his 16yr old daughters car and doesn't really care about upgrades.
2006 Mini Cooper S.
Here's a pic of the cam for your enjoyment!
Old Jun 25, 2018 | 09:33 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I think Out Motoring has just about all of the OEM parts in their system. ECS is another vendor that sells of parts.
Old Jun 25, 2018 | 10:10 AM
Yikes! that's got some wear.
+1 We have it all right here, of course, the old w11 engines are single cam, so you just need one.
https://www.ecstuning.com/Mini-2006-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Engine/Mechanical/
Old Jun 25, 2018 | 10:41 AM
mauls's Avatar
mauls
Thanks guys! i'll also pick up new rockers as well.
Old Jul 3, 2018 | 05:43 PM
mauls's Avatar
mauls
Hey guys, so replaced the head, cam, rockers etc, got it all back together and had a terrible idle and would die. I threw a P1109 code: Manifold air pressure too high under deceleration. I took off the super charger put it back on and let it run for about 5 minutes and it hasn't came back on yet. But now i'm getting a strange idle that jumps up to 1500 then back down to 1000. Everything ran and idled fine before so I wonder if a TPS or MAP just happened to go bad?
Here's a video: (if you click play it has sound)
https://photos.app.goo.gl/Eped6gnh5CYrJwx19
Thanks!
Old Jul 5, 2018 | 04:43 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Seen that many times. My theory is the previous owner didn't change the oil enough.
We sell used ones all the time for this fix
https://www.waymotorworks.com/used-s...0-r52-r53.html
We got new ones too, but they are pretty expensive.
Old Jul 5, 2018 | 07:50 PM
downshift1's Avatar
downshift1
I've got a good used one you can have if you cover the shipping
Old Jul 11, 2018 | 09:40 AM
mauls's Avatar
mauls
Hey guys, I did get a new head, cam and rockers. The issue with my idle was I found that the boot under the bypass valve wasn't all the way onto the throttle body which was causing the bypass not to function properly. All good now!
Hippie
Jun 9, 2010 08:29 AM
Luys
Jul 6, 2008 08:14 PM
bobbiemartin
Classic Mini Talk
Mar 3, 2008 10:08 AM
fozworth
May 16, 2007 11:04 AM
fozworth
May 3, 2007 01:12 AM
