2006 R53 // AC Drier Replacement
Old May 27, 2018 | 12:38 AM
sampleman's Avatar
sampleman
Hi All,
Recently had an AC check up and got the recommendation the change the expansion valve and ac drier. There was pressure on the low side but none on the hi side.
The expansion valve job seems pretty straightforward, but I have not been able to find any details online for the drier replacement. Its hitting 100s already in Austin, and I'm getting afraid !
I will have the refrigerant evac'd at a shop, replace the parts, and then have it filled back up.
Any tips or tricks?
Do I need to fill the drier back up with PAG oil?
Cheers!
Old Jun 3, 2018 | 03:36 PM
A383Wing's Avatar
A383Wing
The AC drier is part of the aluminum condenser in front of the radiator.....you cannot service the drier separately .......and yes, you will need to add AC oil to the unit if you put a new one in......as to how much oil to add, that info you will need to find out from either the dealer or an AC shop......
Be careful, too much oil will cause problems with your compressor
Old Jun 3, 2018 | 08:17 PM
ItsmeWayne's Avatar
ItsmeWayne
It is fairly easy to replace, but getting to it is a pita. Make sure to use the reccomended oil and the correct amout. I will come with the new dryer. Make sure to use the correct oil too!
CRC
Feb 28, 2017 04:37 PM
Omatic
Mar 22, 2016 07:46 AM
bluesmoke
Sep 24, 2013 09:44 AM
goat
Mar 20, 2008 05:53 PM
