clutch pedal feels sticky & gritty
Old May 3, 2018 | 08:05 PM
yyj3869's Avatar
yyj3869
I got my clutch (valeo clutch conversion kit) replaced less than 5k ago. my clutch pedal doesn't feel like it goes down smooth when I push it in. It feels notchy kinda like when I push it in it feels rough. The car shifts fine throughout the gears but the clutch pedal is the problem. I recently replaced driver's side axle and after replaced, clutch pedal felt normal as when clutch was replaced but it went only few days and turned out to be rough again.
I also replaced slave cylinder but no difference. plus, clutch pedal makes squeaky noise when i release the clutch pedal slowly.
Does anyone have any ideas what the problem could be?
Old May 6, 2018 | 01:02 PM
yyj3869's Avatar
yyj3869
any advices?
Old May 6, 2018 | 07:44 PM
JAB 67's Avatar
JAB 67
Most likely a worn guide tube and throw out bearing.
Old May 8, 2018 | 05:05 AM
Subw00er's Avatar
Subw00er
Any way to lube that?
Old May 8, 2018 | 05:37 AM
JAB 67's Avatar
JAB 67
I don't believe so. Why weren't they replaced when the Valeo was installed?
Old May 8, 2018 | 10:20 AM
yyj3869's Avatar
yyj3869
I didn't know it was needed. i brought only valeo clutch kit and rear main seal in the shop.
Old Jun 26, 2018 | 01:51 PM
Subw00er's Avatar
Subw00er
Any update?
Old Jun 26, 2018 | 01:53 PM
yyj3869's Avatar
yyj3869
Originally Posted by Subw00er
Any update?
I've been to different mini cooper service shop and mechanic told me that it's guide tube or clutch plate.
Old Jun 26, 2018 | 01:58 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I agree likely a worn guide tube. It does not take much of roughness between the guide tube and the release bearing to make the pedal feel sticky as the pressure plate spring force is so low. Did OP inspected before reuse the guide tube? And if so did you properly lubricate it with the provided grease after cleaning off any grime?
In theory a worn master cylinder can also cause this, just to cover all bases.
Old Jun 26, 2018 | 03:29 PM
pnwR53S's Avatar
pnwR53S
To not risk taking the drivetrain out in check the clutch, you can try exercise the clutch with you hand using a long lever like I did. The action should be smooth. This remove the hydraulic variables.
Old Jun 27, 2018 | 12:41 PM
Subw00er's Avatar
Subw00er
can you do that with the slave still attached?
Subw00er
Oct 1, 2017 09:42 AM
clevelandrum
Apr 4, 2016 08:15 AM
superbriam
Jan 7, 2015 08:40 AM
ieandro
May 8, 2013 07:43 PM
MrCooperS
Jul 1, 2008 10:41 PM
