Clutch adjustment
Old 04-14-2018, 07:28 PM
minidd99's Avatar
minidd99
minidd99 is offline
Clutch adjustment
Is there any way to adjust the position that the clutch pedal engages/disengages? I can't find this info anywhere.
Old 04-16-2018, 10:07 AM
Rich Rodichok's Avatar
Rich Rodichok
Rich Rodichok is offline
There are many clutch threads on NAM. I've read (or at least skimmed) most of them. I don't recall anyone being able to successfully adjust the engagement point of the clutch pedal. You may just have to learn to drive it the way it is. Hopefully someone else will chime in with a better answer for you. Good luck.
Old 04-16-2018, 11:07 AM
Detroit Tuned's Avatar
Detroit Tuned
Detroit Tuned is offline
Vendor - 15 Years
There is no adjustment on any MINI Clutches.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old 04-16-2018, 07:34 PM
minidd99's Avatar
minidd99
minidd99 is offline
Thanks for the quick answer guys. Looks like I'll have to get used to it.
Old 05-17-2018, 07:17 AM
GBugg's Avatar
GBugg
GBugg is offline
Is a "high engagement" a sign that the clutch is failing? Or simply "the way it is"? Our 07 MCS clutch engages right at the top of the pedal stroke.
Thanks.
Old 05-17-2018, 11:10 AM
MCS02's Avatar
MCS02
MCS02 is offline
MINI Alliance Ambassador
That sounds a bit high compared to my Minis. The clutch will start to slip when it needs to be replaced. Try putting it in one gear to high for the speed you are going then accelerate. If the RPMs go up but the car does not accelerate your clutch is slipping and needs to be replaced.
GBugg (05-17-2018)
Old 05-20-2018, 11:03 PM
asysavanh's Avatar
asysavanh
asysavanh is offline
This was my complaint on the mini whenever I first got it.
Look up burger tuning’s clutch stop or make one yourself. I currently use two shins and it’s perfect for me.
The dual mass flywheel doesn’t help with the engagement either. I switched to a single mass and it’s perfect.
Old 05-21-2018, 06:25 AM
GBugg's Avatar
GBugg
GBugg is offline
For me, unfortunately, the clutch started slipping shortly after I posted here. :-(
So I'll be curious to see if the engagement point is back to "normal" after I change the clutch.
Old 05-21-2018, 10:30 PM
Jermajerm's Avatar
Jermajerm
Jermajerm is offline
Hows the noise with the single mass? I'm about to hit 60k so I'm starting to look at having to replace my clutch in the near future and want to go single.
Danscrazyhair
10-03-2016 12:57 PM
tlhamon
How to
04-21-2014 08:05 AM
peatun
04-27-2013 06:37 PM
dajiggalo
07-20-2008 03:29 PM
Quick Reply: Clutch adjustment
