2006 Mini Cooper S 6 speed Transmission issue
I have an 06 Mini, has about 107k miles, I bought it last month used. Very fun little car to drive. A couple of days ago it got harder to get the stick into gear. I drove it about 30 miles Monday and when I left my house it was feeling fine, by the end of the drive it was nearly impossible to get into gear. Same problem on the way home, I'd have to turn off the car at times put it into first and turn it back on to just get the car into gear. From there I could shift up, but it was rough and a lot of resistance.
I dropped it off at my local mechanic, he says the whole clutch needs replaced, about $1650 for parts and labor. I read up a bit more about mini and transmission issues though, and here are a few questions I'd like to find answers to prior to talking to my mechanic again.
1) Could this just be an issue with the Master and Slave cylinders in the clutch? I understand those wouldn't probably be covered under an extended warranty I purchased on the car when I bought it, but still cheaper than a new clutch altogether.
2) Would replacing the clutch altogether mean they are also replacing those master and slave cylinders?
3) Could I have ruined the clutch driving it back home those 30 miles when it was so difficult to get the car into gear in the first place?
4) Are there any big clues that would stand out to say the issue was a cylinder vs the clutch? They seem like a reputable shop, but I just like to double check before committing to a huge repair.
Thanks to anyone able to help me out with this, I really appreciate the advice before I have to see about a minor loan to deal with a clutch repair bill.
The clutch on these cars is a common failure, my pressure plate actually split into 3 pieces, I was unable to get it in to gear at all. If you replace the clutch, I suggest you get the entire flywheel and clutch combo, the better single mass flywheel conversion.
https://www.ecstuning.com/b-valeo-pa.../52151203~val/
If your transmission is out of the car, and your car is not equipped with a LSD, I highly suggest you get one for your car, it makes a dramatic difference in handling and grip. I personally have a wavetrac in my car. Worth every penny.
It would be good to replace the slave cylinder, though they are notoriously difficult to bleed, its a vehicle specific bleed procedure.
Lastly, assuming his cost of the clutch/flywheel kit is ~$300. The labor should not be more than $1000.
Mini's clutch is not more prone to fail than the most reliable clutches.
eagle
Mar 23, 2014 12:48 PM
LA Gearhead
Feb 15, 2014 04:50 PM
Miami
Aug 24, 2012 12:01 PM
banyan
Nov 20, 2008 06:46 PM
