R53 sway bar end links hitting axle
In an attempt to find the source of a slight grinding noise while slowing from the front end of my 2004 MCS, I noticed the end links have some slight scratches on the lower end near the axle. I think under front end load like while braking or hitting dips in the road the end links are making slight contact with the axle. I can’t find anything else about this so I am wondering if anyone has heard of this happening and what can be done to remedy it. The front rotors, pads, hubs and tires are all new so I don’t believe any of those are the issue. The sway bar end links are new as well. Thanks.
Tim Wiest (03-14-2023)
Vendor
Seen aftermarket end links just like that before that are just made too big so they hit. We just use the stock ones
https://www.waymotorworks.com/sway-b...0-r52-r53.html
Or if you want adjustable go with our WMW ones
https://www.waymotorworks.com/wmw-ad...-endlinks.html
Same problem
Hello everyone new to nam and was wondering if someone could help me out after replacing lca bushing and sway bar links I found a grinding when decelerating
so after looking around I noticed my sway bar links were rubbing my axle it turns out the ebay links I used were the ones built to big so I got 2 new moog say bar links from autozone and even though they are thinner they are still right up against my axle and appear to rubbing ever so slightly still did I put something back together wrong or is this normal any insight would be greatly appreciated thank you.
Medicated _mini (02-13-2020)
Vendor
The following 2 users liked this post by WayMotorWorks:
Medicated _mini (02-14-2020),
ssoliman (02-14-2020)
Super old thread but I have a similar issue where the sway bar end link rubs against the driveshaft when the steering wheel is fully cranked to the right.
Is this an original or aftermarket sway bar end link? Not sure how long it's been like this but looks like definitely for a while. I recently got this from a friend for next to nothing as he bought an M4.
@WayMotorWorks For some reason, I can't access your website. I'm in Canada if that matters.
As I said, the bar moved sideways within its bushings.
If the clearance is equal on both sides, the bar is in...the center of the chassis, right ? If the bar has moved to one side or the other, less clearance on one side...more clearance...on the other side.
Unless your lower control arm is moving front to rear (bad bushing) an excessive amount, that can also happen.
So again, as long as your control arm bushing(s) are in good shape, just force the anti-sway bar back to the center position.
If you are wondering...NO, the anti-sway bar is not bending..!
Mike
Mike
bcrdukes (04-05-2021)
Mike
Mike
r53-06m6
11-09-2018 07:06 PM
JaysinStrife
Suspension
11-18-2015 12:28 PM
