N18 Tensioner Torque
Old Mar 16, 2018 | 08:33 AM
Stump Grinder's Avatar
Stump Grinder
Hello,
Anyone know what torque value a new N18 timing chain tensioner should be installed to?
Old Mar 16, 2018 | 09:46 AM
https://www.newtis.info/tisv2/a/en/r...shaft/DNYlkIXT
https://www.newtis.info/tisv2/a/en/r...shaft/DdLC54pK
80NM = ~ 59ftlbs
Old Mar 16, 2018 | 12:48 PM
Stump Grinder
Thank you
Old Mar 16, 2018 | 01:03 PM
Stump Grinder
Is it really necessary to put the engine at TDC before removing the tensioner?
Old Mar 16, 2018 | 04:13 PM
TVPostSound's Avatar
TVPostSound
YES!!
You then have a reference point, just in case.
Old Mar 16, 2018 | 06:40 PM
Stump Grinder
Thanks, but how can removing the tensioner cause the crank to turn?
Old Apr 23, 2018 | 02:55 PM
Stump Grinder
So, I replaced my tensioner last weekend, I purchased a crank alignment tool from ECS however on my Countryman there is an exhaust bracket that picks up off the bell housing, the bracket extends to cover the alignment access hole. Now this bracket is fastened by one of those stupid external torx bolts. I could get a proper torx socket on it but the exhaust is in the way of the ratchet :-( I was going to go buy a torx wrench but I couldn't be bothered so I put the motor at 90° and did the job.
It was a bugger to get to though, that inlet duct is a real pain, I couldn't get the bottom joint freed but I finally managed to get a socket on the tensioner and a breaker bar. Fitted the new one and managed to get a torque wrench on it, job done.
What surprised me was that the old tensioner came out in 3 pieces, housing - spring and piston, is that normal????
Old Jun 21, 2018 | 06:21 PM
Jorge Perez's Avatar
Jorge Perez
Where can I get my hands on the crankshaft lock tool?
Old Jun 21, 2018 | 06:31 PM
Stump Grinder
Crankshaft or camshaft?
If it's crankshaft I have 2 for sale on Kijiji
https://www.kijiji.ca/v-cars-other/c...ationFlag=true
Old Jun 22, 2018 | 07:05 AM
You can get it in the kit or on its own like stump grinders above.
" What surprised me was that the old tensioner came out in 3 pieces, housing - spring and piston, is that normal????"
Should be all together, not separated.
bweber721
Feb 15, 2017 04:28 PM
themrethank
Feb 13, 2016 05:10 AM
Carlyle
Apr 12, 2015 02:56 PM
mini_aaron
Sep 20, 2014 08:02 AM
pidge1114
May 19, 2014 03:26 PM
