N14/N18 High Pressure Fuel Pump teardown and refresh
Old Jan 16, 2018 | 07:00 PM
  #101
cjv2's Avatar
cjv2
Originally Posted by MiniToBe
What a journey! Lol
The HPFP solenoid has only two wires. Measure resistance for each pump to see if the coils are at least within range of each other.
The seller you bought the item from is a friend of mine now. I bought a lot of items from her for my minis.
Once i get my hands back on my countryman, I tag along and provide you some valuea too. I have two test HPFP that i can play with later.
Lots of things to do but little time. I have an N14 engine to rebuild next.
Ah, compare the solenoid pump values across pumps. Makes sense. Duh
2.8/9 ohms for 3 of the 4: 2013 HPFP (bad behavior), OSIAS HPFP (initial failure stages with oil leak, Sep 2016 "new"), spare HPFP that has never been installed but is "new."
All three of those are off-car. To test the other one I have to start removing things from the engine again (because of everything in the way of the solenoid contacts), and I unfortunately won't be able to do that until next week. So it's not an outlier, it just hasn't been measured yet.
But it looks like we've got a consistent reading across broken and hypothetically not-broken, with a pretty tight range of resistance values too.
Old Feb 6, 2018 | 06:32 AM
  #102
geofox784's Avatar
geofox784
Any updates from those working on this?
Old Feb 6, 2018 | 06:38 AM
  #103
cjv2's Avatar
cjv2
None yet. Waiting for arrival of a tool to better handle the quick disconnect on the low-pressure fuel supply line (which I am going to replace due to damage to the quick connect from, well, not having that tool).
I did receive the fuel rail with sensor a couple of weeks back but had to take a break due to traveling. Once I've got the quick disconnect tool, I'm going to be replacing that fuel line with one whose disconnect isn't damaged, replacing the fuel rail and sensor, putting the fluorosilicone rings back on the junker HPFP, and replacing the intake manifold gaskets (just because). I don't specifically expect major change of any kind, so the big question is whether I'll be surprised.
As I write this, I realize I totally spaced on submitting an oil sample to find out what is living inside the OSIAS HPFP that is leaking. One more thing to get back on deciphering.
Old Feb 6, 2018 | 06:43 AM
  #104
MiniToBe's Avatar
MiniToBe
you can use two philips screw drivers to push and release the hose
I also have a feeling you'll be surprised with the new fuel rail and pressure sensor
Old Feb 6, 2018 | 07:00 AM
  #105
cjv2's Avatar
cjv2
I am hoping I *will* be surprised!
I tried the two phillips screwdriver thing. That's how I got to where I am!!! Not an unsound approach. Just one I got sick of and I found the tool for about $30, wooooo
Old Feb 6, 2018 | 07:02 AM
  #106
MiniToBe's Avatar
MiniToBe
post a link for it... i think the ones i saw where south of $100
Old Feb 6, 2018 | 07:37 AM
  #107
cjv2's Avatar
cjv2
Here you go. Price is currently around $35 and there appear to be multiple sellers. It's a competing product, from CTA Tools, to the super-spendy one you can only find near the $100 price point:
https://smile.amazon.com/gp/product/B06XTJN6TW/
Old Feb 6, 2018 | 07:40 AM
  #108
MiniToBe's Avatar
MiniToBe
https://www.ebay.com/itm/1137-MINI-C...4AAOSwP4FaK9Wl
thank you
Old Feb 6, 2018 | 07:42 AM
  #109
cjv2's Avatar
cjv2
You bet!
Old Feb 6, 2018 | 02:57 PM
  #110
timski's Avatar
timski
Thanks. Ordered on eBay. I hate that connector.
That or the previous owner messed it up long ago.
Old Feb 6, 2018 | 03:42 PM
  #111
cjv2's Avatar
cjv2
Glad to help. Hopefully some other folks find it helpful too!
Old Feb 16, 2018 | 12:28 PM
  #112
MiniToBe's Avatar
MiniToBe
anything new ?
Old Feb 21, 2018 | 04:52 PM
  #113
cjv2's Avatar
cjv2
anything new ?
So I had to do a shaman dance around the Mini to convince itself to reveal its secrets and not fight me getting the lower bolt on the intake manifold out.
Unfortunately, I forgot to ask the dance routine for some favors about getting the fuel rail off, so the Mini said "fine, you can have all 4 injectors out while you're removing that fuel rail, just think of it as one assembly because that's how you're a-gonna get 'em, as a bonus for me letting you have that intake manifold bolt!"
So now that the injectors are 100% out of the engine (but still in the old fuel rail) I'm going to have some questions for you as to their condition and proper replacement protocol. I'll take some pics and post up in about 7 hours (maybe less).
Love this car. It's like a Lego set! LOL.
Old Mar 3, 2018 | 06:22 PM
  #114
cjv2's Avatar
cjv2
Ok, so that took a bit more than 7 hours. But I'm back.
Pics attached. Questions I have are:
(1) What do you make of the condition of these? I have no experience with fuel injectors.
(2) I keep reading (Bentley manual, a couple of other places) that now that these are out I have to replace all the various sealing rings. Ok, fine, if I must, but I want opinions on that and...
(3) Should I get the Genuine Mini sealing parts/kit (P/N 13647600869) or the equivalent Bosch kit? The genuine kit runs about $80 (or higher); the Bosch kit runs $8. I would just go grab the Bosch based on price, but I really want to understand why the price variance is so high.
(4) If I *do* have to replace the sealing parts, that PTFE ring is, from what I gather, a project requiring a special (not cheap) tool. Thoughts?
Injector #1
Injector #2
Injector #3
Injector #4
Old Mar 4, 2018 | 06:21 PM
  #115
cjv2's Avatar
cjv2
anything new ?
Sooooooo we have mixed news.
(1) Decided to just put the damn thing back together. With the replacement fuel rail (and, more importantly, its sensor). Yay.
(2) The fuel line fitting on the replacement fuel rail is larger than the one on its predecessor. Meaning the nut on the fuel line is too small. Meaning I can't put the damn thing back together. Not Yay.
Ummmmm...
So. Suggestions? Maybe swap the new sensor onto the old rail? That seems to be the clearest path, so long as (1) the sensor is in fact same-spec and (2) I get it appropriately torqued, with no idea what "appropriate" means other than 'seems tight enough' (yeah, no...)
EDIT: Confirmed that the pressure sensor part number on both fuel rails is the same. The fuel rail proper is obviously not an interchangeable part, though. :/
Old Mar 5, 2018 | 04:35 AM
  #116
MiniToBe's Avatar
MiniToBe
That could've been from a later built. I know in ebay listing it was for 2011-2014 or something like that. apparently is wasnt. the good news is you have the sensor and that was the hole exercise. swap it and hand tighten it + a little more (maybe 45 degrees).
the injectors above done look tooo bad by the way.
Old Mar 5, 2018 | 05:21 AM
  #117
cjv2's Avatar
cjv2
Cool. Thanks for the feedback. FWIW I should have cross checked the eBay detail more closely - there’s a clear flag that the rail proper is interchangeable only with the exact same part number (and that part number is identified). What bit me is that I couldn’t ID the part number on the existing rail without disassembling everything first, and I hadn’t fully figured out from realoem.com that there were multiple part numbers in play on the MY2011 Cooper S. My vehicle is an early-production 2011 (Nov 2010).
I’ve run into that midyear/when-produced gotcha before, BTW — anyone with a 2011 Cooper S should take it seriously when the parts counter wants to cross check against their VIN, and definitely should check against realoem.com or minifans.info if they can.
I've got one additional feeler out on the torque spec for the pressure sensor -- will hopefully have an answer back fairly soon. Some cross-reference to BMW material for the same pressure sensor (same part number) on a different vehicle points at a spec of 30 newton meters minus 5, but I want to get a hard confirm as to whether that holds.
EDIT: Something I noticed. See pic below. If color is an indicator of material, the blue O-ring that seals the space between the injector and the fuel rail is... drumroll please... fluorosilicone. In photos I see of both the genuine Mini-branded and the Bosch-branded injector sealing kits, this O-ring is the same color and presumably the same material. Makes me wonder yet again about the choice of Viton rings on the solenoid in the stock Continental HPFP for this N18 -- that choice may indeed be a very real reason why part of HPFP failure is always a cold start/need-to-warm-it-up gotcha.
Close-up of removed injector showing rail-side sealing ring.
Old Mar 6, 2018 | 09:51 AM
  #118
cjv2's Avatar
cjv2
Hey MiniToBe --
(1) see post above, I added some pics and an observation that may be of interest.
(2) pic of the replacement fuel pressure sensor. Not sure what that ring is on the tip -- it could be some kind of sealing compound, but not sure. My original does not have this. What do you think?
Tip of replacement (used) fuel pressure sensor with some kind of compound on it -- any idea what it might be?
Old Mar 6, 2018 | 09:56 AM
  #119
MiniToBe's Avatar
MiniToBe
interesting indeed...when I did my countryman, the sensor was clean and didnt have that sealant on it. if you just clean it and install it, it should be fine. I never had a fuel leak with these things.
Old Mar 6, 2018 | 12:02 PM
  #120
cjv2's Avatar
cjv2
Cool. And an update: Mini is put back together. Started up clean -- obviously had to let it repressurize the fuel line after taking all that apart, but once that was done it did some minor stumbling and then just ran. Still up in the air on jackstands, I have to put the lower intake manifold bolt back in place and access is via the RF wheel well, but once that's done... test time, muhahahaha
So at this point, the replacement fuel rail pressure sensor is in, I'm using the junker HPFP, fluorosilicone o-rings on the HPFP's solenoid. I did let it idle for about 5 minutes, then shut it down, cleared codes, cranked it back up -- car went to limp mode rather than kicking the PSI to normal range. My immediate takeaway is that the oil question we were kicking around earlier is germane.
One note: I decided to probe both fuel rail pressure sensors before reassembly. Definite difference between old and new. In particular, pin 1-2 settled in at 10 ohms on the old, but about 11 ohms on the new.
More to come.
Old Mar 6, 2018 | 12:07 PM
  #121
MiniToBe's Avatar
MiniToBe
this is off to a good start...dont worry about that bolt in the back of the intake for now. never know if you have to get in there again.
swap out the pumps and notate any difference.
Old Mar 6, 2018 | 02:50 PM
  #122
cjv2's Avatar
cjv2
I seriously despise that bolt. But I got it back in place before you posted.
So I took it out for a spin. Pretty much same behaviorwise with this combination -- warms up well, but fuel pressure doesn't pick up to normal range until/unless you give it a shove, blah blah blah.
Unrelated to the HPFP: I would have to test some more to be sure, but I think the new pressure sensor is reading a smidge higher when in normal range. With the previous sensor I was seeing [abnormal] dips just below 600/620; now those dips are bottoming out in a higher spot.
Anyway, on to HPFP switches...
Old Mar 6, 2018 | 02:52 PM
  #123
MiniToBe's Avatar
MiniToBe
Cj..cj...cj...
Old Mar 6, 2018 | 03:08 PM
  #124
cjv2's Avatar
cjv2
Cj..cj...cj...
Yeah yeah yeah I know. LOL.
Old Mar 7, 2018 | 08:38 AM
  #125
cjv2's Avatar
cjv2
It may interest people to know that several brand-new Genuine Mini Continental HPFPs, part 13517592429, are floating around eBay around the $500 price point. I've seen 2 from dealerships between $511 and $540, and some from a third outfit (one I'm not fond of, but they have the part) around $449.
Again, Genuine Mini part -- NOT the OSIAS, made in China, that I bought one of only to have it start leaking less than 3 months after purchase (with the manufacturer going dark on inquiry about its supposed 2-3 year warranty). I would recommend staying away from the OSIAS altogether.
If folks are interested in direct links I'll post them, just let me know.
In re my Mini -- I cashed in the Assurant warranty that I put on that bad OSIAS at purchase time, and put the funds towards one of those new Genuine Mini HPFPs yesterday. So now I'm going to have... 5 of them, which means we can smash one with a giant mallet like in the cartoons if we want.
