N14/N18 High Pressure Fuel Pump teardown and refresh
#276
I am experiencing hard to start when engine is cold problem. Recently I have replaced LPFP and fuel filter but the problem remains. High pressure fuel system fault was also triggered on couple of occasions.
Today I have removed HPFP and measured thermal expansion and it is 27mm. I assume that is not good?
I would like to try to rebuild pump myself.
Are you still running rebuilt HPFPs?
#277
I have rebuild my pump 3 times and each time I got about 1500 miles out of it before it started to fail again to the point that the car was not driveable.
18mm is the correct measure and mine has been 27-30mm at quitting time. Your car will probably run ok for another couple hundred miles - apart from the hard starts - until the pump just can't make it go.
When it can't feed the Turbo anymore is one milestone and the next one is that it struggles to downshift when you give it gas to pass someone for example. After that it won't be long.
I have had fun rebuilding the pumpand avoiding that that huge expenditure for a new HPFP, comma but in the end that is what you're going to need. At least they are one of the easiest parts to change on the motor!
#278
@tlbuss Thank you for a reply.
I suppose I should consider buying OEM one as when I monitor fuel rail pressure (actual and specified) when driving sometimes actual pressure is dropping below specified as well. And since I have random hesitation when driving I am guessing that HPFP adds to that problem as well?
#279
#280
cjv2 (12-11-2022)
#281
So far so good car starts right up idling about 4835 kpa- 5600 kpa on punch 9300-10,005+ kpa running great lets see how long we can run this pump. I did a little something different by using Lucas oil treatment with some 80-90 STP gear oil . I also filled the cap with Lucas up to and including the hollow drive shaft before installing. Since the Lucas treatment is thicker it stayed in place. After installation I have about 18 MM measurement from the outside of heat expansion valve to plate, should be plenty of heat expansion room. I remember someone saying a new pump was about 19 mm so should be good. Time will tell.
cjv2 (12-11-2022)
#282
I used 50/50 ratio. I fill the body with STP and the center of the piston pumps then I fill the cap with Lucas while rotating the cam and I did notice you can fill the backside through the hollow shaft of the cam which acts as a crossover for the oil. Have the mounting flanges and screws in place on the cap ready for quick installation when you flip the cap and use a hand drill to install as quickly as possible. Make sure you pull the bolts down evenly so you don't damage the "O" ring. It's messy but compressing the oil in the chamber sets the expansion valve setting to about.750" or 19mm with a caliper. I have had good results by doing this so far. Only way I see the pump using oil is by it escaping through the seal under the drive that engages the cam when running. I have no leaks on the outside. Hope this helps ???
cjv2 (12-15-2022)
#284
#285
For general consumption: I recently joined a Mini Cooper Mechanics group on Facebook, and much to my surprise someone in there pointed someone else in there to an HPFP rebuilder. I can't vouch for this business, never had any dealings with them myself, but sharing just in case it may be of interest.
Link: https://hpfp-mini-cooper-rebuilt.com/
MSD (08-29-2023)
#286
Hpfp
The HPFP is a separate unit from the engine driven by the cam. The bellows in the pump are known to wear out and this would be the only way for fuel to leak inside the pump and just replenishing the oil inside the pump would not work without replacing the worn-out bellows. Hope this helps.
#287
Just wow. Some serious dedication in this thread. I've been researching to rebuild the hpfp on my BMW, and came across a site that has step by step instructions for both the mini and my 135i. After reading all twelve pages of this thread, I felt compelled to register, and share.
Hope it helps, and greetings from sunny South Africa.
https://beisansystems.com/n14-n18-hi...mini-cooper-s/
#288
Thank you so much for the link. So very cool and such good info! And finally a full explanation for what breaks down inside, where, how, and why! I can stop obsessing now lol
MSD (08-29-2023)
#289
Haha, I thought you might like that bit. I was particularly interested in the oil they used, and their filling method. Much simpler than all the other methods I have seen on youtube etc.
I just wish they had posted the sizes of the seals used!! A search on their site for the kit they apparently sell, brings up nothing unfortunately.
MiniToBe (08-31-2023)
#290
Hey guys! This topic helped me a lot. I'm just writing here so if someone has the same issue as me, and searches on it on google, he'll see this.
So my N14 Peugeot 207 had a stuttering issue. I could only use it on 1/4 throttle max , otherwise it would bog/stutter/ hesitate on acceleration/on load.
I have changed the injectors before, thought that was the problem but not.
Haven't had any symptoms on my HPFP at all. No cold start issues, so I didn't really think it was the problem until I checked live data while driving.
When the car hesitated, the fuel pressure dropped down almost to 0, then jumped up to the normal pressure.
Then yesterday I had a spare HPFP which had a 27mm diaphragm depth (which is not good). I took it apart, cleaned it, filled it with 75w-90 transmission fluid, put it back together.
I don't really know the history of this HPFP, but considering that the depth of the diaphragm indicated that its bad, I'm assuming it wasn't so good. After rebuild the depth came down to
13mm (which is way below the factory measurement). I didn't think much of it, it was already a spare so why not run it. Put it on the car, now the car doesn't misfires on idle, no hesitation at all.
I hope I helped. If you have any questions tag me.
Have a nice day.
Have a nice day.
The following 2 users liked this post by Kispeti:
cjv2 (02-09-2024),
swellengear (02-05-2024)
#291
Hey guys,
Thought just add to this topic, with some info.
Just had this issue with my 208Gti N18 HPFP for the second time now. (car done 160k)
I'm a damper/ shock absorber design engineer and run my own business selling shock absorbers for motorsport use in the UK.
Watch a few videos online then stripped a secondhand one from eBay for £50 to see how it disassembled, then did my own.
The oil inside mine is Silkolene 02 damper oil has the same texture and viscosity as the old oil and as it is designed for high-performance dampers it can withstand the stresses and high pressure seen in this pump so I'm 100% sure that this is the correct oil to use for this pump. (a cheaper alternative is Silkolene 5wt both oils can be found at any motorcycle shop as Fork Oil.) using standard engine oil or gear oil won't last as it's not designed to withstand the stress and shearing properties that are found inside this pump and high-performance racing dampers.
I'm also sure that, the main issue is oil loss. properly leaking past the pressed diaphragm.. (the only place I can think it would be.. All the O-rings seals seemed fine in mine.
Also, the diaphragm works as a chamber for oil expansion due to heat however it's also there to apply pressure to the oil to stop oil cavitation which is why it is important to ensure there is no air in the system as it will cavitate the oil as well and cause the pump to not work properly. Feeling the pressure of the spring, I say it needs to measure at 13-14mm when it gets to 21-22mm there is not enough pressure on the oil, and when it gets hot the oil loses viscosity and will instantly cavitate causing it to not generate enough pressure to push the other pistons down. (hence the odd pressures when looking at the fuel rail data from the car.)
ATM the best way to re-oil the pump is to submerge it all in oil and then pull the diagram right back (give it a few pumps to get the air out.) with a pick and then screw it all together making sure the diaphragm is pulled back when screwing it together. then remove the fuel solenoid and clean the fuel passageways out with brake cleaner. (Make sure you remove as much of the oil as possible and clean the fuel filter found inside the intake fuel pipe.
That is all I have done and it is working perfectly fine again. The diaphragm measures 14mm. the car starts when hot and the erratic fuel pressure when idling or holding a steady throttle has gone.
would say it is best to reoil the pump every year to ensure you don't get wear on the moving parts.
Regards,
Alex
Regards,
Alex
cjv2 (02-23-2024)
#292
Nice! Let your Peugeot and Citroen owners know we have the metal water pipes now also. We don't have those car over here and I know their are a bunch in western Europe.
#293
So you're spot on. No question.
Really good post of your details/how-to, and a major thank you for specifying what oil to use. It's a mystery to a lot of people.
#294
HPFP rebuild
Thanks for the info. Im also in South Africa and im looking at rebuilding my girlfriends HPFP. I can't seem to view the content in that link you shared.
#295
I have spent way more time than I care to admit the past week researching how to rebuild these. I have an N54 but these pumps all work on the same fundamentals. One thing I've found that wasn't listed on this thread is replacing the shaft seal. It seems there might be some discrepancy about its size tho. One guy says it's (size in mm) 22 x 11 x 7 and another says its 22 x 10 x 7. It appears to be a double lip seal based on the sections views floating around, curious if a triple seal would be any improvement. I've bought a used N54 pump and intend to tear it down and see what I can discover. I'm currently trying to track down replacements for the "thermal compensator" as well as a the solenoid valve "fuel control valve." It seems the coil at least on the solenoid is a C22 coil, so it's a start. Also for the thermal compensator, I have some leads but it requires more investigation. I have contacted black stone labs and intend to send them a sample of the oil, it sounds like they can identify the grade and viscosity for sure, but that they "would do their best to identify the oil type" So the hunt continues!
#296
I too am trying to view this website, but getting "This content is password protected. To view it please enter your password below:" does anybody know how to get a password? Or can somebody save the content of the procedure shown there and share it?
I've change that oil properly and vac bleed it aswell. To bleed it, you remove the lightly pressed it diaphragm and fill the pump with 5wt shock oil through there and vac bleed it. Then fill the diaphragm with oil and quickly seat it back in and press the part back in.. Making sure to use a sealant around it.
Been trying to understand this issue and I'm sure its the solenoid valve coils that are deteriating due to the heat. It is put in a place that gets no air to it.. When the car get hot and u turn it off for 5 mins. It will struggle to start for say 30mins to 1h.
But if u open the bonnet for 2mins or poor some water on top of the pump The car will start straight up. So basically somehow you need to find a way of keeping it cool. I was thinking of trying gold tape to reflect heat away from it.
But its annoying that bosch do not sell that valve separately or someone hasn't made an aftermarket one for it. As I'm sure that the issue.
#297
Over time the seal goes bye bye. As you have mentioned sealing it, it doesn't exactly make sense for the seal to go bad, have the oil leak out, and have such failure NOT have consequences. Over time the lack of oil used in hydraulically pressurizing the fuel causes [measurable] lack of pressurization and loss of that pressurization = car doesn't get fuel in as fast as it needs. But it doesn't fail catastrophically, it's slow death, and that slow death has been reported widely enough that it isn't really hypothetical.
Solenoid-swapping making no difference at all told me three things.
(1) the common failure, across four separate physical HPFPs, wasn't the solenoid.
(2) a good solenoid couldn't resurrect an HPFP that had failed for "whatever the reason" those four had failed (one had only started to fail, but was actively leaking hydraulic oil despite being "new.")
(3) a solenoid failure was possible because they're man-made, and man-made things fail. But without a known-bad solenoid, which I apparently didn't have, differentiating bad-solenoid-cause from leaking-oil-cause was not possible.
I'm sure a bad solenoid would nuke an HPFP but not in the way that is most broadly observed and discussed to death in this thread.
BTW, I noticed the tie of behavior to temperature as well. Never figured it out, but like you, I noticed it.
FWIW / Cheers
#298
The Temperature of the car been bugging me. As it operates at 104°c {219°f). And the fan comes on at 108°c.. (this is OBD READING NOT instrument pannel.)
Motorsport been apart of my life since i was 6 And i own my own business doing race shocks. But never heard of an engine operating at 106c. Had peugoet dealer, haynes manual and online forums say this is normal. Im always used to optimum engine performance is 70c-80c
My cars done 165k now and i've had timing chain done, water pump ect ect and still okay but performance is always been abit odd. Took my pump off again and still reads 13.5mm like i set it originally. (but got this starting issue.)
So i thought i'd look into this temp issues, and checked the head gasket and you notice a very small leak brownish line to the coolant jackets. (mine cylinder 2) so i changed head gasket. (making sure it head was clean) and did valve stem seals aswell.
However, instead of using the basic g12+ red coolant with water as i've normal been using. I switched to G30 ready to use high performance coolant which has a boiling point of 160°c instead of 100°c (that is used for high performance cars and motorsports/ track days) it needs to be deionized water with the coolant.
And instantly the car now operating at 70-80c i've got better throttle response and power and i've not had a single issue with the hpfp pump since. (which i was constantly having issues on the standard fluid.)
So thinking it more an engine temp problem than the pump. As only had two hpfp first one played up at 125k. (which when i started doing services myself as i had the extend warranty on it so getting peugeot to do services.)
And the second one started playing up at 150k which is the one i reoiled and is now working fine with this performance coolant in.
So if someone having pump issue see what car temp is and try a high performance coolant and deionized water rather than standard cheaper stuff with tap water . As the part number the peugeot dealers use is 9735KO.
Worth a try than spending hundreds on fuel pump. (ready mix version cost me £30.
cjv2 (05-11-2024)
#300
Several parties here have noticed what I can only call "stuff" that seemed to be temp-dependent, myself included, but couldn't nail down particulars or a pattern. I even got as far as noticing that changing out the Viton solenoid rings for fluorosilicone ones could make a *little* bit of a difference for cold start behavior (but don't do that, those fluorosilicone rings deteriorate something awful over time, even when just sitting doing nothing on a bench).
Your observations and mine alike point to a temperature/materials intersect, which actually makes intuitive sense, but I never got as far as thinking about cooling the entire engine down period. Interesting to say the least.
Poetxpress
05-02-2014 10:03 PM
