Rally driving light
Old Nov 28, 2017 | 07:45 AM
bcgreen's Avatar
bcgreen
Rally driving light
I noticed the other day one of my rally lights not working. I saw a piece of metal stuck between the outside metal cover and the glass. I think that piece of metal is probably a spring that holds the light tight.
So my question where do I get another light and is it dissembled by undoing the screw at the bottom?
Old Nov 28, 2017 | 08:13 AM
Here is the light 63120137303
https://www.northamericanmotoring.co...s-oem-hel.html
There is a little spring clip i believe that presses against the ring to hold the reflector in place. I would undo the bottom screw and see whats going on. And see if that bulb is burned out.
Old Nov 28, 2017 | 08:25 AM
bcgreen's Avatar
bcgreen
If I just need the bulb is there a number for it? I am wondering if local parts store would stock it?
Old Nov 28, 2017 | 08:29 AM
Yep,
Right in this link with aftermarket options: 63217160779 OEM or 63170412647 or the Ziza H3 bulbs
https://www.ecstuning.com/Mini-2005-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Lighting/Rally_Lights/
Old Dec 1, 2017 | 02:38 PM
bcgreen's Avatar
bcgreen
Any suggestions on how to undo the screw on the bottom? I don't want to strip the screw, but I have put in a lot of muscle and it just is not budging.
Old Dec 2, 2017 | 11:15 AM
bcgreen's Avatar
bcgreen
Okay, after alot of banging with screw driver, hammer and chemicals I was able to take it apart. The sealed bulb looks fine so I can't really tell if it's bad, but I am going to say it is since I made contact with a deer. He bent the base down and I had to straighten it out.
Reading the bulb it says on the back: 03102002
The lens reads as: JUTE 9614 HR (E 13) 10
040261
Old Dec 2, 2017 | 12:24 PM
Capt_bj's Avatar
Capt_bj
would the install instructions for the factory kit help?
https://www.minimania.com/pdfile/NMA3030_INSTR.zip
Old Dec 2, 2017 | 12:34 PM
bcgreen's Avatar
bcgreen
Not really, but thanks.
Old Dec 4, 2017 | 11:27 AM
Those are the bulbs linked above just pop out that sealed beam front and pop the bulb out the back. Otherwise if its beat up from the dear you might have to get a whole unit.
Old Dec 4, 2017 | 11:29 AM
bcgreen's Avatar
bcgreen
Old Dec 4, 2017 | 11:47 AM
Welcome.
Old Jul 5, 2022 | 08:55 PM
BatteryBoyBob's Avatar
BatteryBoyBob
I have a bunch of these lights. How many do you need?
702-788-0122
Old Jul 6, 2022 | 07:05 AM
Fly'n Brick's Avatar
Fly'n Brick
702-788-0122
Two things: 1, the OP posted this thread five years ago. I've an idea he's found a solution.
2, Edit your phone number off the page immediately! There comes a troll from time to time who'd love to have it, phone numbers and email addresses on any forum
are a no-no. To communicate person to person, use the private messages function. Common terminology "PM me" when you want one on one comm.
bcgreen
Dec 7, 2017 07:02 PM
joedotmac
Aug 4, 2015 11:22 AM
AKmcs
Sep 22, 2011 08:53 PM
bigrex
Apr 3, 2010 10:12 AM
Yucca Patrol
Apr 6, 2004 07:17 PM
