Oil leak from a vacuum pump??
Old Oct 25, 2017 | 07:00 AM
Talknrok's Avatar
Talknrok
Ok, I'm sure to get some sighs form people who have head to many variations of this problem but here goes. I am experiencing huge oil consumption with no visible reason. No leaks, no smoke. I have read about vacuum pump issues on r56s and the horror that can happen if they aren't fixed. Can anyone tell me if that is a problem with 05 r50 base coopers? Do they even have a vacuum pump? I took a quick glance this morning as i checked the oil and didn't see anything in the suspected area except the coolant fill/tsat housing.
Old Oct 25, 2017 | 10:04 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
NO R50, R52, R53 cars don't have vacuum pumps so that is not your issue.
Old Oct 25, 2017 | 01:14 PM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
How much oil are you consuming? I probably wouldn't worry about it if unless it's more than like, a quart every 1000 miles or so.
Old Oct 25, 2017 | 02:39 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Stock Problems/Issues area
Old Oct 26, 2017 | 05:13 AM
Talknrok's Avatar
Talknrok
Sorry if I started the thread in the wrong place. Yes I found some engine parts drawings and confirmed no pump. I have a new pcv valve ordered but I cleaned mine last night and it wasn't really stopped up at all. I still want to check the vacuum pressure at the valve cover but I don't expect it to be bad. I haven't gotten an exact figure on consumption yet but I am guessing 1qt+ per 1k. Still getting in the mid 30's for mileage and a little over 120k on the odometer. It has never been an oil user but on my last oil change I came up about a quart low draining it. Didn't think too much about it. Not very long into this last oil change I heard lots of clicking at startup till the oil made it up to the head and valves. when I checked it I was alarmed to find oil on the tip of the dipstick. Took nearly 2 quarts to bring it back to the middle of the marks. Been checking daily now that I'm properly scared of losing my engine but I need to figure out why the sudden change. I did recently change the valve cover gasket due to a slow leak that just made the back of the block messy but never enough to drip. Can't see how that could have anything to do with it but I have seen stranger problems.
Old Oct 26, 2017 | 05:35 AM
Whine not Walnuts
No problems with where you posted, rather have you ask the question than not ask at all.
Have you thought about putting some UV dye in the oil? Under black light you will see if you have anything leaking on the outside. Also, you have checked the coolant for milkshake goo, correct?
Old Oct 26, 2017 | 10:17 AM
Talknrok's Avatar
Talknrok
The UV dye is a great thought, I will have to try that. Yes I have checked to coolant and oil for mixing from both directions. My only guess is that I'm burning it which makes me wonder if it isn't showing as smoke, what might it be doing to the CAT.
Old Nov 2, 2017 | 05:39 AM
Talknrok's Avatar
Talknrok
OK Got the new PCV in and oil topped off. It needs a change but I would like to get some miles on it to see if this makes a difference.
Old Nov 3, 2017 | 10:47 PM
sarom058's Avatar
sarom058
Good luck, let us know how it goes!
Euler-Spiral
Dec 2, 2020 11:53 AM
bgibbs@nine-eleven.com
Aug 17, 2017 07:44 PM
jrw429
Apr 10, 2017 10:21 PM
Jckol
Dec 29, 2016 08:52 PM
Redpepper31
Oct 20, 2016 08:24 AM
