Engine skip
Old Oct 24, 2017 | 04:09 PM
Outcorner77's Avatar
Outcorner77
Engine skip
I have a 2006 cooper s that has a skip when I throttle it hard. I have replaced the plugs, wires, fuel filter and (Detroit Tuned) bypass valve. All of this needed to be done anyways but did not solve the problem. It does it when I give it a quick deep throttle. If I throttle up easy it won't do it. I also cleaned out the throttle body when I replaced the bypass valve. Any suggestions?
Old Oct 24, 2017 | 04:28 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you back to the Gen1 area, Stock Problems/Issues. Did you change the coil pack when you did the plugs/wires?
No codes correct?
Old Oct 24, 2017 | 04:32 PM
Outcorner77
I did not change the coil pack and was wondering if that could be it. Your correct no codes.
Old Oct 25, 2017 | 03:53 AM
Whine not Walnuts
On my R53, got a skip and changed the coil pack. Solved the issue. How many miles on the car? Original coil? Coil electrodes rusty?
Old Oct 25, 2017 | 09:55 AM
Aspen's Avatar
Aspen
Second the coil pack. They are known to cause issues once they get older.
Old Oct 25, 2017 | 10:03 AM
Outcorner77
I have 131k miles on the car and I'm going to guess it's the original coil because I'm the second owner. The electrodes are clean because I changed the wires. It sounds like the consensus is the coil, I'm going to try that. Thanks everyone!!!!
Old Oct 31, 2017 | 10:03 PM
Outcorner77
A quick update for all of you who replied to my problem. My new MSD coil came in today and I pop that right in and took her for a test drive and she's running great!!!!! Thanks everyone!!
Old Nov 1, 2017 | 07:30 AM
Aspen's Avatar
Aspen
Excellent! Thanks for the update.
rlotus
Oct 9, 2016 02:08 PM
dpcompt
Sep 18, 2016 07:28 PM
jbing
21
Jan 2, 2014 07:20 AM
chrisneal
21
Dec 15, 2002 04:42 AM
2minis
Sep 28, 2002 02:19 PM
