Front Bumper Question 2006 R50
Old Apr 18, 2017 | 06:03 PM
Cenla Mini's Avatar
Cenla Mini
Long story short...the engine guard that connects to the bumper on my 2006 R50 came loose and both the black part attached to the bumper ( see picture of left and right) or perhaps it's part of the bumper) has just about worn out and the part the "U Nuts" extruded (see picture) slips over for the M6 X 16 bolts screw into to tie it all together has also broken where the "U Nuts" are attached. I may be able to repair it with some kind of repair compound but if I can purchase a replacement that would be better. What I cannot tell from both my Bently manual and the online parts suppliers is if this is a separate part or integrated into the bumper...does anyone know?
Left Side
Right Side
U-Nut Extruded
Old Apr 21, 2017 | 04:39 AM
Cenla Mini's Avatar
Cenla Mini
No one has had a similar problem?
Old Apr 24, 2017 | 04:39 AM
Cenla Mini's Avatar
Cenla Mini
Well...I've PM'd both Way Motors and ECS Tunning but haven't heard from anyone. Guess this is not a common problem and I'll need to tear it apart to see if there is a way to fix it with some kind of epoxy.
Does anyone have any suggestions on ways to repair plastic parts like this?
Old Apr 24, 2017 | 08:06 AM
rkw's Avatar
rkw
The black spoiler is available separately from the bumper, part# 51117127932
http://www.realoem.com/bmw/enUS/show...diagId=51_5803
Search the part numbers at vendor websites, or just Google the part numbers to find vendors.
Old Apr 24, 2017 | 08:32 AM
Hello, Just saw the PM.
I had my damaged on my R52. The little nut goes on the bottom of the core support and then the bolt goes through the lower spoiler to the core support mounted nut insert.
https://www.ecstuning.com/Search/SiteSearch/51117127932/
and
64500630991
https://www.ecstuning.com/b-genuine-mini-parts/body-nut-priced-each/64500630991/
and
07146971298
https://www.ecstuning.com/b-genuine-mini-parts/hex-bolt-with-washer/07146971298~oem/
Make sure the nut clip can grab onto the lower trim. My hex bolt was rusted pretty bad on the nut insert clip. I just hit them with some grease.
Old Apr 24, 2017 | 07:12 PM
Cenla Mini's Avatar
Cenla Mini
Yes...that's what I'm talking about! I'll be ordering it this payday
Old Apr 30, 2017 | 03:53 PM
Cenla Mini's Avatar
Cenla Mini
@ECSTuning ...Got my parts in and replaced the lower spoiler without too much difficulty! Thank you for the help. I did find the "Body Nuts 64500630991 to be the wrong ones I was looking for although they were required/needed to attach the two ends of the spoiler to the left and right side trim made of the same material as the spoiler. I now have an ample supply of these (bought 10). The nuts I was looking for were actually like this one...I have one and need two more. They attach the spoiler to the Core Support Front Panel...which sadly I'm going to have to replace in the future as well since the left and right contact points are damaged...although I may be able to repair it if I plastic weld an insert.
Here is the picture of the nut I need...
Old May 8, 2017 | 06:48 AM
Welcome.
Yep sorry this is the core support bottom one. The other one is needed also when i did mine.
07131496622
https://www.ecstuning.com/b-genuine-mini-parts/body-nut-priced-each/07131496622/
Old May 9, 2017 | 12:11 PM
Did you see my last post?
Old May 16, 2017 | 04:12 PM
Cenla Mini's Avatar
Cenla Mini
Sorry...didn't see it until today! Thanks...I was out of town for the past week and didn't have a chance to check the forums. Will be ordering tonight!
