Troubleshooting help, power loss, trying the correct subsection this time
No boost, in my own measurement, coming from 2 things -- MAP readings on the OBD2 datalog and the basic feel that it has about 125hp. Before, unless I was going all out, you could barely get your foot to the floor in first because of the acceleration. Certainly nowhere near the power it had before, in any gear. No turbo lag or power building as boost would build -- flat as the panoramic roof.
I have not checked the CAT -- good point.
New replacement and all I checked was that the wastegate would close under vacuum -- didn't do the full measurement as I have found directions to do so.
Maybe while checking the cat, you could visually check the WG too?
WG is normally open until vacuum pulls it closed. I will definitely go back through and check it out.
I have manually operated the WG using a mity-vac, so I know it closes -- visually verified that vacuum would pull it completely closed prior to installation. But it never hurts to go back and make sure I didn't screw something up during installation.
Update as I continue the saga...
So far:
* replaced turbo (play in the bearings) with new B/W OEM replacement (new DV and wastegate as part of the unit)
* tested pressure side tubing, holds 15psi with no leakdown
* installed new, temporary vacuum line from pressure controller (solenoid) to wastegate
* measured vacuum at wastegate and receiving enough to actuate the wastegate
* did a couple Seafoam treatments via PCV hose
Code p2885, half power indicator, and (still) no boost. Otherwise, runs and drives well.
Next up, replacing the full set of vacuum lines, vacuum solenoid, map/air temp sensor.
So far:
Will be gone for a few days, but had a chance to take the Mini to work today. Installed the new MAP sensor in the boost tube, cleared the codes and left the scanner connected to see some live data.
Still comes back with the 2885 code, but it is making some boost now. I can see the boost controller (solenoid) and diverter valve actuation being called for by the ECM. Noted 1230 hga as a peak, 3rd gear WOT out on the highway, so I'm assuming I am seeing 18psi, but *very* much lag. I did learn that the ECM commands the charge solenoid as you increase throttle, but normal steady state, does not -- as I interpret it, the wastegate is released/opened under normal stead state, but every time you increase the throttle, it activates the solenoid, and pulls the wastegate closed.
To the suggestions above, I haven't had a chance to pull the heat shield and validate the wastegate linkage adjustment. I did take a peek thru the O2 sensor with the borescope, wastegate fully closes when manually actuated and the CAT looks clear from the top side.
When I say lag, I mean, it used to jump forward in 1st or 2nd when you ease on the throttle (in sport mode) -- that doesn't happen anymore. Same with rolling on in a higher gear.
Guesses, at this point, seeing as how all of my other experience with non-Mini's has been turning out to be somewhat irrelevant...
* not enough vacuum (now that I learned more about the ECM and solenoid operation), via weak vacuum pump, bad solenoid, or collapsing lines (have the new lines and solenoid, but haven't installed)
* something I haven't attacked, carbon buildup in the intake
* wastegate linkage adjustment
Sorry for all the rambling. One day when I figure this thing out, I will simplify into a troubleshooting guide. Appreciate the input from the hive.
I get confused easily --- what is your "1230hga peak" reading? Almost looks like a vacuum reading using inches of mercury on an Absolute gauge. 1230 would be a huge vacuum and nowhere near 18PSI Boost. If you're converting positive boost PSI to inches Hg (a bad idea), use a minus sign. Take a look at an external manifold pressure gauge that uses both units for confirmation. If this is a reading from a scanner, what function is it?
OEM waste gates are operated on a duty cycle --- not continuously as you suggest. When WGDC is read at the OBD II connector, it's shown as a percentage. They can be tested using a constant source, but the ECU pulses it at a variable rate, as needed for driving conditions. You can test the vacuum pump by connecting it directly to the WG diaphragm and watch the linkage --- linkage moves, pump is OK.
"the boost controller (solenoid) and diverter valve actuation" as you describe them, when actuating, are both dumping boost. Your "boost controller (solenoid)" is actuating the waste gate, dumping boost into the down pipe, and the DV is dumping it back into the turbo air inlet.
Yeah, I seem to be confusing myself regularly on this motor.
I'm using the Schwaben scan tool (from ECSTuning), under the Mini diagnostics and live data monitoring -- don't have the ability to change the measurement units in most cases.
Maybe a more simple question -- is the solenoid a normally open (vacuum flows through) or normally closed (no flow, dumps the vacuum from the output line)?
When I hit the throttle, the solenoid shows as "activated" -- I'm reading that as goes from open to closed (applying vacuum and closing the wastegate). When I let off throttle between shifts, the DV activates and bleeds off boost back into the inlet.
I can try, as you suggest, connecting the WG directly to the vacuum pump (have done it before at idle) and watch it pull the WG closed. I'm also assuming that driving that way is asking for a blown headgasket or other major failure.
I'm using the Schwaben scan tool (from ECSTuning), under the Mini diagnostics and live data monitoring -- don't have the ability to change the measurement units in most cases. Is your 1230 reading boost, or something else? If this tool didn't come with an instruction manual, maybe work with ECS to learn how to use it.
Maybe a more simple question -- is the solenoid a normally open (vacuum flows through) or normally closed (no flow, dumps the vacuum from the output line)? I don't believe the solenoid is normally anything --- it operates on a duty cycle. Probably more operation during boost than any other time. At idle (high vacuum) the solenoid should be closed.
When I hit the throttle, the solenoid shows as "activated" -- I'm reading that as goes from open to closed (applying vacuum and closing the wastegate). When I let off throttle between shifts, the DV activates and bleeds off boost back into the inlet. I would read "activated" as "ready to cycle". DV activates when the ECU tells it to.
I can try, as you suggest, connecting the WG directly to the vacuum pump (have done it before at idle) and watch it pull the WG closed. I'm also assuming that driving that way is asking for a blown headgasket or other major failure. My suggested connection is only for testing purposes. It should not be driven this way.
Big_iz, your 1230hga has been bugging me --- any chance it could be 1230 milli bars (1.23bars) instead of hga? Using bars as a unit of barometric measure is common in other countries, and 1.23bars is a low but reasonable number when boosting.
Sorry, OBW, been out of town a few days, just got back last night.
Re-read my own typing and I screwed up -- should be hPa (hectoPascal). I'll dig the scanner back out tonight, pull up the data, and RTFM this time
Ygritte
Jan 22, 2019 06:48 PM
Car Care Products
Mar 17, 2016 03:35 PM
