Motor Rattle started yesterday MINI Cooper S 2003
Old Mar 6, 2016 | 10:31 AM
xpcdoojk's Avatar
xpcdoojk
I am the original owner of the car. It has about 75,000miles, I noticed yesterday with the windows down that there was a loud rattle coming from the engine. It was occuring at all speeds, the car seemed to be running perfectly from an engine response view. What is it? Anybody else reported this? Doing a search I find lots of death rattle threads about R56 engines, but not R53.
Help!!!
JC
Old Mar 6, 2016 | 12:08 PM
Hot.Damn.'s Avatar
Hot.Damn.
Could be several things, pop the hood and determine where about the noise is coming from. Could be belt tensioner, heat shield rattle, maybe supercharger, etc. timing chain cassette are very common failure on R56 but I haven't personally seen any on a first gen go bad.
Old Mar 6, 2016 | 12:58 PM
buzzsaw's Avatar
buzzsaw
Crank pulley dampener?
Old Mar 7, 2016 | 10:21 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you sure it's from the engine bay and not possibly an exhaust or suspension rattle up front? Does it occur at idle? Or when sitting and revving it up a little? Can you post a video for us? Might help.
888.280.7799 | 6am - 5pm PST
Old Mar 7, 2016 | 11:15 AM
xpcdoojk's Avatar
xpcdoojk
It is definitely in the engine bay. When I pulled it in the garage, I opened the hood and it was loud. I am reluctant to fire up the car until I have an idea what I am dealing with. I hope someone hear will offer a clue.
JC
Old Mar 7, 2016 | 11:45 AM
PelicanParts.com
Vendor
Could be a number of things as Hot.Damn. mentioned above. Here is a video on NAM with a rattle issue someone had. See if it may be similar to your sound.
Old Mar 8, 2016 | 08:10 PM
<05MINI>'s Avatar
<05MINI>
Two most common rattles on the r53 are the supercharger and belt tensioner. However my 05 R53 had a rattle I just fixed and it turned out to be the alternator. It was starting to seize and was cracked in three different spots.
Old Mar 9, 2016 | 07:06 AM
xpcdoojk's Avatar
xpcdoojk
My rattle is more prominent than that video. Sounds the same all of the time, throttle makes no difference. It sounds like it is right at the top, which I would guess would imply the supercharger.
JC
Old Mar 9, 2016 | 09:12 AM
R53Minicoop's Avatar
R53Minicoop
My 06 R53 just did the bad tensioner timing chain rattle a few weeks ago at about 74k. Changed the tensioner out - 10 minute job. Fixed her up in a jiffy. If it is the tensioner used a 3/8 wobble head extension and you can change it out without taking anything else off.
Good luck whatever it is.
dw3
Aug 1, 2016 04:17 PM
clarkjk3nt
Factory JCW Talk (2009+)
Mar 14, 2016 08:50 AM
onlycoopers
Feb 3, 2016 12:20 AM
