Throwing Multiple Throttle and one o2 code
Old Feb 25, 2016 | 11:34 AM
Justin Nemec's Avatar
Justin Nemec
my 2009 mini cooper s is throwing throttle codes P1637,1638,1639,2102 and 2103. Also throwing downstream O2 sensor code P0141.
I replaced the O2 sensor and the heating element voltage will not cut off after warmed up. The wiring harness checks out.
I am at my wits end. Any ideas out there?
Old Feb 25, 2016 | 12:01 PM
nkfry's Avatar
nkfry
1637- Throttle control deviation
1638- Throttle temporarily stuck
1639- Throttle permanently stuck
2102-Throttle actuator "A" control circuit stuck low
2103- Throttle actuator "A" control circuit stuck high
All of these point to ice in the intake.
Tackle the above codes first, which will either require you removing the intake tube from the throttle body and cleaning the condensation and oil out of the bottom of the tract, or replacing the intake manifold with the cold weather manifold which was designed to fix the icing problem.
We have the intake manifolds in stock and ready to ship, they are $40.43 plus shipping.
Give us a call if you have any questions.
Nick
586-792-6464
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 25, 2016 | 12:05 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P2102 throttle actuator control motor circuit low
P2103 throttle actuator 'A' control motor circuit high
P1637 throttle valve position control: control deviation.
P1638 throttle valve position control; throttle stuck temporarily.
P1639 throttle valve position control: throttle stuck permanently.
This guy here had a few of the same codes you have and replaced the throttle body, which fixed his issue.
Any other symptoms besides the codes? Is it cold where you are and would you say that your MINI is sputtering? I've seen P1637, P1638, P1639 associated with the intake icing issue. If it's acting like this you could have an intake icing issue. Some info HERE and the cold climate version intake HERE. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
Old Feb 25, 2016 | 12:27 PM
Justin Nemec
I'm located in Fort Worth, Texas. Not real cold but can get to freezing overnight at times but not very often. Sputtering is under acceleration and then LIMP mode kicks in.
Old Feb 25, 2016 | 12:30 PM
nkfry's Avatar
nkfry
I've only seen one case of it, but I had a customer who's throttle body electronics were full of oil, only detectable when you open the throttle body up (not recommended unless you're replacing the old one).
Phone:586-792-6464
Old Feb 25, 2016 | 12:43 PM
PelicanParts.com
Vendor
Some info on P2102 and 2103 HERE was a throttle body - Post #12.
fixedsix
Jun 15, 2016 08:07 AM
Feb 1, 2016 02:17 PM
rwhatter
Jan 28, 2016 09:04 AM
Jan 27, 2016 01:19 PM
DustinFennell
Jan 27, 2016 08:52 AM
