Knee Bolster removal
Old Jan 28, 2016 | 04:41 PM
pkunk's Avatar
pkunk
The only threads I can find are about 1st gen MC. I don't want to brake anything. I see some screws at the bottom, what else is there to get the DS knee bolster off?
Old Jan 30, 2016 | 07:40 PM
pkunk's Avatar
pkunk
378 views and no-one knows how to remove?
Old Jan 30, 2016 | 08:14 PM
cerenkov's Avatar
cerenkov
If you are talking about the large piece under the steering wheel, remove the 3 screws on the bottom and pull. It will pop off. You can't really break anything.
Old Jan 30, 2016 | 08:17 PM
pkunk's Avatar
pkunk
Pull from the top after removing the screws?
Old Jan 30, 2016 | 08:24 PM
cerenkov's Avatar
cerenkov
I usually pull from the bottom. You'll hear it go pop, pop. There are 4 hidden posts holding it on.
Old Jan 31, 2016 | 12:21 AM
rkw's Avatar
rkw
No need to remove any screws. It has friction fit posts at the top and tabs along the bottom that are shaped to work like a hinge. Pull at the top until it releases. If it doesn't release, you aren't pulling hard enough (don't be a wimp about it). Once the top posts release, the panel tilts down and is easy to pull off from the hinge tabs at bottom.
http://www.mini2.com/forum/faq.php?faq=faq_interior (scroll down to "How to remove interior bits")
Old Jan 31, 2016 | 04:47 AM
cerenkov's Avatar
cerenkov
Is that for the 2nd gen? I've removed the panel a dozen times and never noticed the hinge feature.
Old Jan 31, 2016 | 08:50 AM
pkunk's Avatar
pkunk
Thanks cerenkov, that's what I was looking for!
Old Jan 31, 2016 | 10:41 AM
rkw's Avatar
rkw
Oops, my bad! I didn't notice that this is in the 2nd gen forum.
Old Feb 3, 2016 | 08:53 AM
The panel looks like this on the back and comes out. http://www.realoem.com/bmw/enUS/show...31#51162757647
https://www.ecstuning.com/Search/SiteSearch/51162757647/
Eurothrasher
Mar 17, 2016 02:59 PM
theblackfalcon
Feb 8, 2016 06:54 AM
PelicanParts.com
Tires, Wheels & Brakes
Feb 2, 2016 12:10 PM
mtnmikev
R60/R61 Stock Problems/Issues
Jan 26, 2016 08:39 PM
