Gp2 turbo installed and now having problems, HELP
Old Jan 21, 2016 | 04:34 PM
  #26
metatron's Avatar
metatron
Originally Posted by metatron
did you solved the problem? i'm having the same problem on a N18 cooper s, but stock turbo.
stage 2 catless, panel filter, intercooler
Try reading the voltage in the battery, i've discovered that mine was gone (1.3V) !!!
After that over 5000/5500 no sputtering or hesitating or whatsoever!
Pull like a train!
Old Apr 8, 2016 | 04:20 AM
  #27
archigab limited's Avatar
archigab limited
Try
Maybe you need to install a bigger fuel regulator, to regulate the more fuel to support the power u put in....
Hope it help...
Old Apr 8, 2016 | 05:15 AM
  #28
cerenkov's Avatar
cerenkov
Hope it help...
These cars are direct injected utilizing high pressure fuel pumps driven by the cams generating upwards of 2000 psi fuel rail pressures. Fuel delivery (time and duration) is precisely controlled by the ECU and piezo-electric injectors.
I'm curious as to what "bigger fuel regulator" you would recommend?
Old Apr 8, 2016 | 08:03 AM
  #29
Yea, never heard of one for a Gen 2 turbo , its a HPFP. https://www.northamericanmotoring.co...r-r56-jcw.html
Which one did you find ?
Old Apr 11, 2017 | 12:14 AM
  #30
youngsbos's Avatar
youngsbos
so any good news from the OP? I am interested in this topic! hopefully he got the solution and enjoying his 07 mcs.
Angryirishwench9
Mar 30, 2020 08:24 AM
nicokin89
Feb 13, 2020 08:33 AM
pbkirby
GP Talk
15
Dec 6, 2016 06:52 PM
cosmicamnesia
Sep 19, 2016 06:48 PM
MarioKart
Jul 30, 2014 11:48 AM
