Temp gauge, fan???
Old Feb 24, 2015 | 08:41 PM
moto827's Avatar
moto827
Temp gauge, fan???
I have an 05 Mini Cooper s and just had to replace Throwout bearing. Because of this I went ahead and replaced clutch while I had it apart. Once everything was back together I started the car and the temp gauge was maxed out with the light on. The fan turned on within seconds of starting. When I turned the car off the fan wouldn't stop, until I tirned key back to on position. Had to unplug the the power to the fan.. If anyone knows what would be causing this or how to fix it it would be greatly appreciated!
Old Feb 27, 2015 | 03:47 PM
David.R53's Avatar
David.R53
The temperature sensor for the temp gauge is on the cylinder head, just about the transmission housing. Did you check that you got the wire reattached correctly?
PsychoRallye
21
Feb 17, 2019 06:08 AM
whowantstorace
Sep 27, 2015 06:16 PM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
rustof
11
Sep 25, 2015 10:35 AM
