cabin a/c fan
Old Jan 12, 2015 | 08:36 AM
bneer's Avatar
bneer
cabin a/c fan
The inside heater fan is beginning to make whirring noises. Are these difficult to change? I'm guessing this will become worse as time goes on.
Old Jan 12, 2015 | 09:04 AM
ZippyNH's Avatar
ZippyNH
You can try lubing it...
Remove the cabin filter...
And put a bit of grease on you finger...and reach WAY UP..about when you armpit is in the hole, you will feel the fan, etc...you can carefully lube it...
Did mine about 5 years ago...no issues.
Old Jan 13, 2015 | 11:23 AM
bneer's Avatar
bneer
cabin fan
Sticky, thanks for that info. Do you lubricate the back of the fan, like does it sit in a carrier? Just wanting to know what to feel for and where to apply grease.
Old Jan 13, 2015 | 11:27 AM
bneer's Avatar
bneer
cabin fan
I apologize Zippy. Thanks for your help.
Old Jan 13, 2015 | 12:11 PM
ZippyNH's Avatar
ZippyNH
I did two things...
I tried to get some around the center hub/bearing area...
I first used some mobil1 spray lube with a super long red hose...from a seafoam sprayer I think...was just long enough to point into the hub area...then tried to push some mobil1 red grease into it...seems to have fixed it...
I think more is not better, key is location...my might have put a trace on the edge..don't remember, but if you feel around, and look at the skematics, you will have a good idea of what you are feeling.
I understand it is a fairly big job to swap out the fan...so worth a try.
Brochacho
Sep 29, 2015 10:24 AM
kevinlhr310
Sep 27, 2015 02:31 PM
dragonby
Sep 25, 2015 08:10 PM
rt808
Sep 25, 2015 01:59 PM
