Grinding noise on acceleration/deceleration?! HELP!
Old May 4, 2014 | 09:38 PM
thevastdifference's Avatar
thevastdifference
The skinny:
Pre Jan-2003 MCS R53. 115,XXXmi. Noticed this noise after I got my megan coilovers on 11-2013. Not sure where it's coming from, wheel bearings are new, rotors and pads are new. (changed on 3-2014). Engine mounts are about a year old. Tires are quite new, purchased 12-2013.
Guessing it might be the clutch? My clutch has been starting to slip, thus the sluggish acceleration.
Help!
Mini Cooper R53 Grinding Noise - YouTube
"> Mini Cooper R53 Grinding Noise - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
Old May 5, 2014 | 04:03 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Though I could not pick it up on the vid I would suspect axle. Probably the RF from lowering your suspension.
Have not heard of anyone having much luck with aftermarket axles when lowered, most say they will last about 2/3 months, so better off with OEM.
Old May 5, 2014 | 05:38 PM
thevastdifference
specifically the RF? do you mean Right Front?
yeah, it seems to be faint in the video, but its quite loud from the cabin. I did just change the passenger front axle.. but they were indeed aftermarket. OEM was a little pricey, but it seems that might just be the solution..
i'll try to make a better video too.
thanks for the input!
Old May 5, 2014 | 05:48 PM
ottawa's Avatar
ottawa
In my opinion do not go after market or re manned unless it's the 600 or 800 whp version axes from a drive shaft. I've seen a nice pair made with porsche cv bits. Looked hot.
Simply go on used - car parts and buy the lowest mile ones you can find. Should be 100.00 to 150.00 per axel and cv.
Mark
scfiveo
Sep 27, 2019 02:27 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
unxpectederror
Oct 22, 2015 12:16 PM
FatherG
Oct 3, 2015 05:06 PM
Miniwaukee
Sep 29, 2015 09:22 AM
