Rust at bottom of tailights
Old Jan 4, 2018 | 06:33 AM
  #26
No, not that i knwo of, I think you are thinking about the trunk battery area on the R53 2005+? My taillights areas have no drain on my R52.
Old Jan 4, 2018 | 06:57 AM
  #27
iwashmycar's Avatar
iwashmycar
Two words. Fluid Film.
If you have any rust you can 'convert' it and paint it if you like...then apply FF. Or just apply FF and not worry much.
Old Jan 4, 2018 | 07:05 AM
  #28
burley's Avatar
burley
I though there was a hole in early R53s in the hatch channel that allowed water to get inside the body somehow that was later plugged. I read it quite a while back, so maybe there are cobwebs in the way.
How does water collect in the tail light? Is it just on the exterior where the tail light foam touches the body? Not from inside? Maybe I'm thinking of another weak point..
Love the screen name, very appropriate, lol.
Old Apr 18, 2018 | 06:25 PM
  #29
matthew-w's Avatar
matthew-w
Originally Posted by burley
I recall reading something about a design change involving a drain plug so water doesn’t collect to begin with.[/left]
I have a 02/2006 build and I took advantage of the extended perforation warranty in December (I sort of wish I didn't based on the result). I had rust and bubbling on both sides.
I mention that because I don't think there's any draining mechanism on my build. Water pooled up around the tail light before the fix and it is pooling up after the quarter panels were replaced.
If anyone has suggestions regarding preventing water from pooling in the tail light socket I'd be interested.
PsychoRallye
21
Feb 17, 2019 06:08 AM
Scm68
Jan 27, 2016 12:33 PM
rikaro
Nov 24, 2015 02:05 PM
minieater
Oct 28, 2015 02:15 PM
unxpectederror
Oct 22, 2015 12:16 PM
